#11 |
Liked 309 Times in 104 Posts
Try removing timing dial control I've seen starter savers,retard boxes,the start retard that is built some boxes. {6AL doesn't have}etc. go bad and cause start issues. Try car with just 6AL no extra boxes and see if that fixes it if doesn't try to borrow another 6AL from someone to verify your's is OK.Make sure starter is grounded to block scrape paint from block where starter mounts could be weak ground and just the slight added load of ignition could make the difference.As Joe mentioned check timing while cranking
could help diagnose. Mike Taylor3601 |
#12 |
Liked 16 Times in 5 Posts
I agree with Mike about the weak starter. Also, is your marine battery deep cycle? They sometimes don't deliver.Hope you find it. bob Michael.
#13 |
Liked 11 Times in 8 Posts
Any update on your issue? Joe
Joe Buchanan SS/BX 3117 |
#14 |
No updates, I have to work all weekend. Im going to head to the garage Monday. Ill keep you updated. Thanks to all who responded
