Liked 354 Times in 120 Posts
So with the 1.40 run under will they give the hemi an index hit or just put more in the box?
Tom Meyer 5240 SS Stock ??? |
Liked 83 Times in 32 Posts
Who where
Liked 68 Times in 41 Posts
1 1517 SS/AH Jim Daniels, Bristol PA, '68 Dart 8.331 9.75 -1.419
2 1990 SS/AH David Barton, Robesonia PA, '68 Barracuda 8.475 9.75 -1.275 3 1945 SS/AH Gary Wolkwitz, Annandale NJ, '68 Dart 8.493 9.75 -1.257 4 403H SS/AH Stephen Hebert, Westlake LA, '68 Barracuda 8.560 9.75 -1.190 5 350 SS/AH Jim Pancake, Delaware OH, '68 Dart 8.578 9.75 -1.172 6 1968 SS/AH Chuck Comella, Sanibel FL, '68 Dart 8.585 9.75 -1.165 7 138 SS/AH Wendell Howes, Rothesay Nb Can , '68 Barra 8.591 9.75 -1.159 8 100H SS/AH Tyler Hard, Harrisburg PA, '68 Barracuda 8.635 9.75 -1.115 9 1954 SS/AH Bob Wolkwitz, Darien CT, '68 Barracuda 8.667 9.75 -1.083 10 1381 SS/AH Mark Howes, Rothesay NB, '68 Dart 8.769 9.75 -0.981 11 1979 SS/AH John Baughman, York PA, '73 Dart 8.794 9.75 -0.956 12 1960 SS/AH Al Smyth, Uxbridge MA, '68 Barracuda 8.850 9.75 -0.900 13 1601 SS/AH William Kraft, Lockport NY, '68 Barracuda 9.655 9.75 -0.095
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
Liked 8 Times in 5 Posts
If they follow procedure it will be 17 horsepower added on to the automatics. That means they will be carrying 102 more pounds. Looks like Westcotts new stick car is not such a bad idea. Think anyone else will start shifting gears and save the weight?
is that a run at the record,i bet wescott will come back out loaded and ready to get it back if it is.
I didn't realize there was a different weight break between the sticks and autos? Just thought they would be the same.
There is no difference in weight breaks between the stick and auto, just HP, stick is at 500, auto is at 507... soon to be at 517+ ... great run Jim ...
Chuck Beach 3340 STK |
I thought the 1.40 rule only apply at points races and national events, not at national opens.
Why would they give them weight as they don't run against any other combo heads up !
They are alone in that class with no other makes or engines allowed.... |
Liked 439 Times in 116 Posts
Hey 69 ss/rs ya wish, 1.40 is the limit, unless you are at a alt. track
John they are still on the reg Q.sheet, but i do agree with ya, but it should be the same for any class run off WIDE OPEN, no HP hit, then you would see more car's in there proper classes and the correct weight's but all aside Congrads to Jim, nice pass Brian |
