Old 10-28-2009, 03:44 PM   #1
Dyno
Dyno's Avatar
Liked 685 Times in 204 Posts
Smile Acid/Chemical Dipping Stripping
Any recommendations on where or who can still acid dip or chemically strip doors/fenders etc.? Thanks, Dyno
Dyno is online now   Reply With Quote
Old 10-28-2009, 04:22 PM   #2
Crisco
Liked 44 Times in 20 Posts
Default Re: Acid/Chemical Dipping Stripping
Dave Kaluasa
248-866-3995
I know he did some stuff for Wayne Hutton on his SS'er.
Crisco is offline   Reply With Quote
Old 10-28-2009, 04:49 PM   #3
Bruce Witherspoon
Bruce Witherspoon's Avatar
Liked 5 Times in 3 Posts
I have a source here in Michigan that I have used for 20 years.
Bruce Witherspoon 3656 SS/KA
Bruce Witherspoon is offline   Reply With Quote
Old 10-28-2009, 05:08 PM   #4
Ron Miller
Liked 13 Times in 7 Posts
What is your location, that would help.
Ron Miller is offline   Reply With Quote
Old 10-28-2009, 05:35 PM   #5
Dyno
Dyno's Avatar
I am in the Mpls./St. Paul, MN area. Upper midwest location would work best. How about that .15 hit I took yesterday! Thanks, Dyno
Old 10-29-2009, 02:27 PM   #6
Dick Kirkpatrick
Same one that Chrysler used in the 60's?????????????
Dick Kirkpatrick 3033 SS
Dick Kirkpatrick is offline   Reply With Quote
Old 10-29-2009, 07:50 PM   #7
Bruce Witherspoon
I really don't think so.
Old 10-30-2009, 07:42 AM   #8
njk53
Be cautious with chemically stripping any automotive part that the metal overlaps, such as a door. It is nearly impossible to get all of the stripping agent out from between the seams. You may think you did a good job of washing the seams but the part will leach stripper even after what you thought was a thorough job.
A friend put together a beautiful 64 Dodge Dart in which the doors had been chemically stripped. The acid leached out onto the new paint corroding it, making a mess of the fresh paint job. He went as far as taking the doors off and tried to thoroughlly clean out the seams sealed and repainted with no luck. It got better but they still leached the stripper. He ended up putting on two doors that were blasted with plastic beads.
As a rule I will chemically strip parts with no seams and bead blast the parts that do.
Just my .02 cents.
Nelson Kowal
Stock 345
Old 10-30-2009, 08:48 AM   #9
raceewing
When stripping with acid the acid must be neturalized with a high ph (alkaline )then rinse with a iron phosphate that will hepl neturalize the alkaline. Wait with about a week before priming to allow all moisture to dry.Then use a 2 part self etching primer.
raceewing is offline   Reply With Quote
Old 10-30-2009, 09:18 AM   #10
Chuck Beach
Chuck Beach's Avatar
Liked 58 Times in 13 Posts
Send a message via AIM to Chuck Beach
Question Re: Acid/Chemical Dipping Stripping
Bruce,
How can you dip fiberglass?
Chuck Beach
3340 STK
Chuck Beach is offline   Reply With Quote
