Old 11-14-2009, 04:43 PM   #1
the bozman
Default 1.92 TCI SuperSet, Straight cut, BG400, Dedenbear, COAN converter
TCI 1.92 PG planetary gear set. Straight cut gears, awesome shape, welded carrier, billit pins, pictures show everything. over $1300 new, will take $650.
Coan 8" converter, AA fin angle, $500 with Coan inpput shaft.
Will sell them together for $1000 plus the ride
BG400 pump great condition $250
Magna fuel 4-port regulator for $120
Gary Williams Dominator, 1050, flows in the 1140 range. HP 3 circuit carb. $650 obo
Will sell it all together for $900
Also have 2 Dynomax Collecter mufflers for 2 3/8 tubes, temp coated, will sell the pair for $125.
Deadenbear Throttle stop for a Dominator, electric with both primary and secondary blades. Works perfect. $250
Steve Harvey
HarveyRacingTeam@yahoo.com
903-399-8255
the bozman is offline   Reply With Quote
Old 12-08-2009, 01:36 PM   #2
the bozman
Default Re: 1.92 TCI SuperSet, Straight cut, BG400, Dedenbear, COAN converter
Trans items are gone, mufflers are gone, still have the
BG400-$225,
Aeromotive A1000 bypass regulator- $100,
and autometer guages (volt, water temp and oil pressure $125 all three or $50 each)
Gary Williams Carb $650- pending sale
