#91 |
Liked 6 Times in 4 Posts
Alan wrote:
"The distribution of wins has NOTHING to do with the red light rule. And nothing to do with the red light rule, either." Alan, is this from the departmenrt of redundancy department??????? ![]()
Bill |
#92 |
Liked 282 Times in 103 Posts
Ever since this topic has become such a "HOT" one,it seems as though the "double redights" are happening even more.I've only experienced it once or twice in over 25 years of racing.This certainly can change the final outcome of a drag race.Here is another example:
Car#-Driver(Opp'nt)-RT-----ET-- Speed-----Car#-Driver(Opp'nt)-RT-----ET-- Speed 7980 Steve Wann 2 Jimmy DeFrank E3 -0.003 9.928 132.67 ****WINNER**** -0.006 8.873 138.07 SS/HA Dial: 9.98 (+/-): -0.052 SS/BS Dial: 8.78 (+/-): 0.093 Prior rounds: E2 (D Durham ) 0.025 10.064 0.154 (B Cunningham) 0.038 8.851 0.071 E1 (J Taylor ) 0.000 9.960 -0.020 (J Larkin ) 0.063 8.811 -0.009 Qualified: #22 9.949 -0.951 #14 8.911 -1.039 Jimmy DeFrank wins on a red light. He races Mason next round. |
#93 |
Gary,
There was 1.2 sconds between those lights.... DeFrank probably saw the win light in his lane and left.... Not a reaction time based on a real "leave..." My 2-cents....
Bill |
#94 |
QUOTE=Alan Roehrich;151451]I did. Try reading. I'll give you a clue. It has something to do with changing the balance.[/QUOTE]
What "balance" are you referring to; one that would spread wins evenly around the classes? That would be sportsmanlike. Give everyone the same chance. What other kind of "balance" could you be talking about? Here is the "balance" we now have: Stock Eliminator wins, 2009 season, 24 races contested: AA/S through K/Stock: TWENTY WINNERS L/S through W/S: FOUR WINNERS That's a 500-percent disparity. FIVE-HUNDRED PERCENT!!! Stock Eliminator WINNERS, 2009, by class: AA-3 A-3 B-1 C-1 D-3 E-3 F-2 G-1 H-3 I-0 J--0 K-0 total = 20 ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++ L--0 M-2 N-1 O-0 P-0 Q-1 R-0 T-0 U-0 V-0 W-0 total = 4 Is this what you call "BALANCE"?????? AND, YOU"RE CONCERNED ABOUT UPSETTING THIS "BALANCE" by changing a rule that, by your own admission, takes away the "faster car advantage???" RE: "you'd like to take this advantage away from guys like Bertozzi, Biondo, Fletcher, and others." I don't think ANYONE deserves an advantage. YOU obviously do... Maybe you'd like to explain the logic behind that. Alan wrote: >>>"Thank you for exposing your misguided agenda Bill, now that I see it for what it truly is, I see there is no need to further discuss it with you, as I can now see clearly your goal is merely to try to take something from people you see as the "haves", and give it to those you see as the "have nots". ![]() So, this is your latest "KILL THE MESSENGER" ploy.... Because you think you've discovered a nefarious motive in my "agenda," you can take this opportunity to cop out, and choose not to discuss it further, since you have put yourself between a rock and a hard place in suggesting that this rule change might upset the "BALANCE," but then realizing that there IS no "balance" (A FIVEHUNDRED PERCENT DISPARITY????) you want to end the discussion... LOL! Have you yet figured this system out to the point that you understand that removing a car from red light jeopardy is an advantage that can not be repaid by the second-to-leave car???? There's no "balance" there; the second car to leave can receive immunity from a red light (if the first car bulbs). That can never happen to the first car to leave. Once again; where's the other side of that coin, and why don't you answer the question????????
Bill Last edited by bill dedman; 11-16-2009 at 12:46 AM. |
#95 |
Liked 100 Times in 45 Posts
Billy,Billy,Billy,come on now and take your medications and come to bed now.You're up past your bedtime.It's affecting your thought process.Check your addition on the list for us poor down trodden
lower class racers. 1-1-2 =4.Now go to bed and dream sweet dreams of a fairer and nicer world.
Former NHRA #1945 Former IHRA #1945 T/SA |
#96 | |
ALAN said: >>>"The slow car spends less time "on the chip" or "on the converter". The slow car driver has less time in which to anticipate the light. The slow car is less sensitive to track prep. The slow car gets a clean tree." Bill said: "And, which of these are the result of rules/legislation??? NONE None of these scenarios were created by NHRA to "level the playing field..." Alan said: "The fast car is less affected by weather. The fast car almost always has his opponent and the finish line in the same field of vision. The fast car is easier to get to react. The fast car, as it stands, has the "first red light" rule." Bill said, "And, which of these are the result of deliberately enacted rules/legislation??? NONE None of these scenarios were created by NHRA to "level the playing field.." The first red light rule was born by default; no options, at the time." Alann said, "The slow car is harder to get to react. The slow car is more affected by weather. The slow car almost never has his opponent and the finish line in the same field of vision. The slow car often has less options at the finish line. The fast car does not get a clean tree. The fast car spends more time on the chip and/or on the converter. The fast car has more time to anticipate the light. The fast car is far more sensitive to track prep." "And, which of these are the result of deliberately enacted rules/legislation??? NONE None of these scenarios were created by NHRA to "level the playing field.."" You simply CANNOT jockey rules around to give an advantage to this car, or that car, because, as I said before, you cannot quantify changes like that; you have no way of knowing HOW MUCH it helps one car, or hinders another.... so, the rules have to be the same for everybody, otherwise, where would this sort of thing end??? It wouldn't..." Bill also said, "Rules have to be the same for everybody.... and.... They're not, in the first red light case. The last car to leave can benefit from something the first car to leave NEVER can; the removal from red light jeopardy by a red light in the other lane. Doesn't matter if it's an A car racing a B, or a V car racing a W... the effect is the same. Screw job, if the first car bulbs, and the last car to leave has a worse infraction, which is always a possibility. Alan wrote: >>>"Bill, I always loved it when the so called "smart people" tell everybody else they "don't understand how they're getting screwed", and the "smart people" are "there to help them" ![]() Bill wrote; "You aparently don't read much of what I write, to try to demonize me with comments like, "Do you really think you are that much smarter than everyone else?" I have commented on this subject frequently, saying things like "I'm not the sharpest knife in the drawer," and "someone smarter than me, (not too hard to do)", and I've commented at least three times about how long it took for ME to understand the vagaries of this "first red light rule"/"worse red light" business. Does that sound like someone who thinks he's smart?? One more time: This worse red light rule is in no way my creation. I had nothing to do with its genesis. It took several explanations, over about a 2-month period, for me to fully understand what it was, how it worked, and WHY it needed to be implemented. I resisited for a long time,because I was brainwashed by a system I'd been using since 1963 (and, this was in the nineties!) Yet, because I said there are people who don't fully understand it, you want to make it sound like I am insulting them, and making myself sound like I'm "smarter" than they are. I said no such thing, and your tactic of putting words in my mouth to that effect, will be recognized for what it is... trying to shift the focus from the subject at hand, to your attampt to discredit my credibility by making me a bad guy.... someone who thinks he's smarter than the othrer people on this forum. Quit putting words in my mouth; you can't find those words in any of my posts. ++++++++++++++++++++++++++++++++++++++++++++++++++ ++++++++++++++++++++++++ It is said that: Great minds talk about ideas. Lesser minds, talk about things. Small minds talk about people. RE: "The race with Fred Suiter was not heads up, and I didn't get screwed out of a damned thing. I went red, I screwed up and lost the race. What happened to Fred's chance to go red??????????? Oh; he got a free ride to the next round because of something you did, but if he'd done the same thing you did, only a thousandth worse, YOU wouldn't have been the winner, anyway, as things stand. That's not getting screwed? What would you call it, when the software exists to compare your light to his, and award the win to the car wth the lesser infraction (yeah; like a breakout.)??? No chance of that as things stand; you got screwed by the system not putting him in the same jeopardy you had to face. Your screwing came courtesy of an antiquated software system that gave Fred the advantage. But, your good-hearted nature thinks that' just fine... What a guy!!! You said, " Balance is where there are advantages and disadvantages to everything, and they cancel each other out as close as possible, achieving some level of balance. Which is what we have now." You still think we have "BALANCE," with a PROVEN, 5 - to-1 disparity in wins between the top half of the field and the lower half, over a one year period?? (2009) How bad would that have to get before you thought it was "OUT OF BALANCE???" Tell me; I'm vary curious as to what your idea of a desirable "balance" number might be. And, why....
Bill Last edited by bill dedman; 11-16-2009 at 04:10 PM. |
#97 |
Ed said,
"come to bed now." Getting into bed with you, Ed, is not something I'd ever want to do, even if I WERE on medications. They don't make one that strong... Hunt for a bed partner somewhere else...
Bill |
#98 |
The handicap system is in place to somewhat equalize performance advantages in the different classes (at least during qualifying). The "unintended consequence" of the first red light loses rule is, it is an absolute contradiction to first or worst.
It has nothing to do with track prep or clean trees or weather. Attempting to prop up those as reasons for not changing the track timing systems' computer software is deflection and obfuscation. |
#99 |
Liked 101 Times in 52 Posts
If both leave before the tree is activated, (one driver seeing the other move leaves also) are not both disqualified because it is a safety infraction?
#100 |
That's how it used to be, but that rule has been changed. The driver that leaves second is given the win. This is sometimes called the "John Force Rule" because of his involvement in a double DQ a couple years ago.
