Old 12-26-2009, 04:55 PM   #1
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Default Valve Spring Compressor?????
I am in need of a new valve spring compressor since my old stamped sheet metal compressor is not quite enough to pull in a 1.500 dual spring. So I am contemplating either going with the Proform 66832 or LSM SC-800. The SC 800 would be nice since I could use it on and off the engine, but it is on the spendy side. Does anyone have experience with either product? Or is there another one I should consider as well?
Thanks,
Chad
Chad E532 is offline   Reply With Quote
Old 12-26-2009, 08:05 PM   #2
SPS
Liked 3 Times in 2 Posts
Default Re: Valve Spring Compressor?????
You'll buy no better spring compressors than those from LSM, nor deal with better people than Tim Smith.
Buy it and you'll never fix or replace it. Forget that Chinese copycat stuff.
FJ
SPS is offline   Reply With Quote
Old 12-26-2009, 08:11 PM   #3
FED 387
Liked 332 Times in 180 Posts
Exclamation Re: Valve Spring Compressor?????
LSM--- the Rolls Royce in quality-workmanship-accuracy----Listen to FJ most of the top running cars use LSM products----money well spent---comp 387
Old 12-26-2009, 10:49 PM   #4
Chad E532
Chad E532's Avatar
Thank you for the feedback. The LSM compressor will be arriving soon.
