Old 01-27-2010, 08:36 PM   #11
W J
Default Re: Decals !
Originally Posted by Bob Verwold View Post
Wasn't that back before paint.........couldn't help it
ALMOST before paint, Bob.....You still see a new "waterstruck" decal now and then, but on glass is where you'd better use them.....never did have much luck removing them w/anything but a razor blade....No kid, but I sure do love to act like one..... WJ
Old 01-27-2010, 08:59 PM   #12
pro70z28
Originally Posted by Sean Kennedy View Post
Any autobody shop should have those, some people call them plastic razor blades. Use a heat gun to get the glue good and pliable, than use the 'razor blade' to scrape the sticker off if necessary. Goo Gone like mentioned above is good for the residue. Easiest possible way to do the job.
The plastic razor blades are like a rigid squeegee. The rotary eraser goes in a drill or air tool and rubs the decal off. Both work. They make a heavy duty unit called a vinyl zapper (large rotary wheel) electric or pneumatic drive, they run about 400 bux though.
pro70z28 is offline   Reply With Quote
