Liked 2 Times in 2 Posts
Indy top end (heads, intake, roller rockers and valve covers) these are the dash 1 heads, magnum block w/ aluminum main caps 55 over, steel crank, eagle rods, wiseco flat tops, Comp roller cam, Milodon gear drive, external oiling system, new rings and gasket set, needs bearings to be put together, several pans, flexplates and flywheelstke it all $3500
Liked 2,486 Times in 697 Posts
Where are you located?
Motor has been sold.
