Old 02-15-2010, 07:44 AM   #1
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
Default Push rod limitations
I run a 350/ 330 IHRA crate motor with .435/ .465 valve lift. we just pulled the engaine apart for freshening and some of the push rods have slight rub marks on them from where they come up through the heads. i am definately going to add more clearance in these areas but i also have been reading lots on the trend to go towards larger diameter push rods. Mine are the 5/16 - .083 wall and was thinking of going to 3/8 dia. Any thoughts?
Thanks
Ian
Ian Hill is offline   Reply With Quote
Old 02-15-2010, 08:38 AM   #2
richie 2
Liked 205 Times in 93 Posts
Default Re: Push rod limitations
push rods that rub slightly in the guide slots are norman. make sure there is enough/not too much clearence. i dont think that size a cam and springs warrent 3/8" units. be sure the ones you have are hardened. .083" should be fine & lighter.
Old 02-15-2010, 11:41 AM   #3
buzzinhalfdozen
Liked 11 Times in 8 Posts
You cannot determine pushrod needs based on lobe lift only. You need to consider lobe profile as well as the spring pressure, I didn't see that you were running guide plates, however assuming you are it would be normal to see some rubbing. I found at bleast on my setup that going to larger pushrods actually made more power, of course every combo is different. Joe
Joe Buchanan SS/BX 3117
Old 02-15-2010, 12:06 PM   #4
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Ian, the marks you're seeing are normal with that diameter pushrod. no need for 3/8, if you are uncomfortable, get some .116 wall 5/16 to reduce the flex. a small amount weight added on this side of the rocker is not as big a deal. do not enlarge the opening unless you're going to use guide plates.
Wade
Old 02-15-2010, 05:52 PM   #5
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Smile Re: Push rod limitations
Go with the bigger diameter pushrods and thicker wall thickness. You can't get a stiff enough pushrod so it doesn't deflect.
Glenn Briglio is online now   Reply With Quote
Old 02-15-2010, 06:32 PM   #6
Dragsinger
Liked 99 Times in 60 Posts
Ian,
do you have guide plates or self-aligning [rail type] rockers?
Larry Woodfin 471W
Old 02-16-2010, 02:42 AM   #7
Jeff Lee
Jeff Lee's Avatar
2x. And if you follow this advice I'll bet you won't need to clearance the push rod slots in the heads or have guide plates. The issue is flex, not lack of plates. Right? Fix the problem. Go faster.
Jeff Lee 7494 D/S '70 AMX
Old 02-16-2010, 01:07 PM   #8
Ian Hill
Ian Hill's Avatar
thanks for the replies and PM's. i do run guide plates and clearnaces look good by eye, the holes are tight but i wouldn't have assumed that much flex in the push rods or movement in the rockers. i will be opening the clearances in the head and will for certain purchase new push rods when the cam and lifters are ordered.
Ian
