Ok, I know this sounds simple but what oil is everyone using these days in a mild..... say 10.5 to 1 small block with a hydraulic cam? Maybe sees 6200 rpm max. Chevrolet iron heads also.
People are trying to steer my to really expensive oval track oil like Joe Gibbs brand. Isn't there any normal oil anymore that is any good? Thanks much! Ron |
Liked 520 Times in 132 Posts
Mobil1
#3 | |
Liked 138 Times in 51 Posts
Personally, I prefer Amsoil products and use their Dominator series in my race car. Amsoil Flat Tappet and Camshaft Lobe Lubrication TSB: http://www.syntheticwarehouse.com/br...lat_Tappet.pdf Amsoil source & info site: http://www.thelubepage.com |
Liked 53 Times in 25 Posts
Mobil 1 also.
Dennis P Chapman 1904 STK NHRA National Record Holder Car Owner. |
Liked 535 Times in 110 Posts
I've run Mobil 1 in the past, but beware, they have removed much of the ZDDP to meet new emissions standards. I do believe that Mobil 1 has recently introduced a racing-only oil that does not have to meet emissions and has the necessary ZDDP additives.
Jim Kaekel 3836 STK |
Probably a silly idea, but I've used the new Mobil 1, but with some GM EOS added to put the ZDDP back into the oil.
By the way, I've bought and used the ultra expensive Joe Gibbs oil and saw no improvements :^( I suppose I was faster as my wallet was lighter ($12/quart!!!)
Rich Hedden 6011 BF/S Last edited by Oclk Dlux; 02-16-2010 at 01:43 PM. Reason: another thought |
Liked 20 Times in 15 Posts
Funny thing about modern motor. It is designed with detergents that remove particle build up on parts and internal surfaces. We have all seen old motors that are covered in sludge.The dtergent is desined not to allow this to happen. The detergent and the ZDDP compete for every surface that the oil touches. The ZDDP tries to bond to bare metal surfaces, under heat and pressure, and the detergent keeps removing it. So where is the protection? I am not sure of the Joe Gibbs race oil but the break in oil has no detergent in it. That's why it is superior for breaking in any new motor especially a high lift/high spring rate flat tappet cam. The ZDDP can plate itself to all the friction parts of the motor( cam and lifters) without fear of the detergent removing it. Brad Penn and Sunoco Blue race oils have lots of ZDDP and small amounts of detergent when compared to modern day oils. A synthetic oil flows better than a conventional oil. As such it coats the surfaces easier than a conventional oil. With this aspect, its lubricity is greater that a conventional oil. As a race engine, a motor gets better attention that a everyday driver and the sludge build up is never an issue. If you look at road race engines( not the exoitcs) they use 20-50 in their crankcase. They qualify,compete and win with that thick stuff. As S/SS racers we would use water if it could work. So for a recommendation I would say Brad Penn. Its reasonably priced, it's a partial synthetic, has plenty of ZDDP, low detergent levels and that green color(naturally occurring in it's crude state) is easy to read on the dipstick.
Liked 13 Times in 9 Posts
CAM2 Blue Blood Racing Oil. It's a high zinc and high phospherous formulation. I run their full synthetic 0w30 in my crate motor Stocker, which I also bracket race -- combined for 55-58 races a year. I feel that the thinner oils are more consistent in the late rounds as they can't thin out like a heavy oil when you've gone through a lot of heat cycles.
CAM2 also makes 15w30 and 20w50 synthetic blends, and gear lube as well. You can order right off their website, cam2racing.com
Liked 484 Times in 160 Posts
Valvoline VR1 oil for street use, Valvoline Racing oil (the not street legal type) for racing engine. Both have ZDDP. As many will recall this oil topic was discussed on this forum a while back , in great length.
I'm going to try Schaeffer 20w40 blended oil. I heard some great things about it on the dyno and from the circle track guys. We will see how it is on the dragstrip. It's a lot cheaper than a lot of the other racing oils. And it is green like Brad Penn
Art Leong 2095 SS |
