Old 02-25-2010, 11:34 PM   #21
Scotty D
Default Re: Manual Trans Help
hey drooze keep up the good work on pop's car can't wait to see it run and see the numbers.on the other question in stock if i'm not mistaken you can use the same amount of forward speeds that the car came with from the factory,that being said why go to a 4speed when you could use a 5 or 6 speed and go to a deeper low gear set with not as much rpm drop on the gear changes to keep the motor in its powerband easier and make it more efficient.
Scotty D is offline   Reply With Quote
Old 02-25-2010, 11:38 PM   #22
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
Thanks
Well......why not 6 .... hmmm.....
I guess if the motor has the "umph" why not go with a wider ratio and 4 , less shifts, less potential for error, I have yet to see a really fast and consistent 6 speed out there (dosent mean there arent , I just havent seen it)
That being said, 1-4 seems ok...and the ratios available for the T56 seem nice for that (the 1-4) cant see using .83 in a drag car ever ? (could be 110% wrong though)
Thats why Im asking....
Cheers
Chris
Chris "drooze" Wertman is offline   Reply With Quote
Old 02-25-2010, 11:53 PM   #23
Scotty D
in a 5 speed aplication you could go as low as you wanted as in a 3.50 low gear and evenly space out the rest of the ratio's to help with the rpm drop off on the gear changes.in the 4 speed it would be like a 3.0-3.2 low gear an then second would be in the 2.0-1.9 range and there would be a bigger drop off than there would with a 5 speed.i do know that a ss/ah stick team tested with 4speeds and 5speeds and these were the results that they came up with,the car was faster with the 5 speed and the powerband was more managable because it didn't have to be as wide as with the 4speed.
Old 02-26-2010, 05:02 AM   #24
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
"Prolly" not. If you're setting your car to run up on the hill, I'm not qualified to comment.
In a non -altitude situation , I'd say that's way too much first gear for a light , V8 car.
It'll hurt more than it help ...Launch , clutch setup , and even mph , if you can believe that.
I ran a 3.97 first in my 2300 turbo Mustang ,but for an entirely different reason.
oh, i'm not saying that it's the desirable trans BUT i have it and it won't be going on the "good" engine...
i think i figured out once upon a time if this car ran a 14 flat up here, it's be a record run...
btw, the rear is an 8 3/4 mopar w/4.57 gears (8.5x26" tall tires, ain't room for anything taller or wider)
Old 02-26-2010, 05:10 AM   #25
Tom keedle
Tom keedle's Avatar
Originally Posted by Mike Taylor 3601 View Post
Tom slik,
That trans is weakest T-10 made&ratios are terrible. 3.42/2.28/1.46/1-1.
1-2 is not bad 2-3 can you say bogggg?3-4 is not bad but still drops rpm pretty bad. Back when I first started racing still drove car on street broke my trans buddy had one of those 3.42 first T-10s traded him out of it I knew it was super t-10 but had no ideal what the ratios were,pulled out of garage knew 1st was lower.eased through gears made sure it worked
turn around launched it on way back 1st was quick went 2nd I thought hey this feels good went to third I thought it was going to kill engine. 2-3 has gear spread about like GM bulldog 4 spd has on 2-3 shift. Made about 6 passes in 12.70 street tire car not sticky street tires plain ol back in the day N-50s.
Soft clutches absolutely help but I would'nt run a stock style trans unless I have to which I do in my Pure Stocker.
I see ol Nash's sometimes 800.00 and up Liberty is selling there version of nash 5 spd. and all the parts are supposed to interchange with original nashes there have faceplate style sliders.
If you buy a 2 or 3 T-10s you have come close to a new Jerico.600.00 up is about going price for good used T-10,then if you pro shift it you spent about another 300.00 if you can tear apart & put back together yourself. I have'nt checked in last year or so but new Jerico
was about 2500.00 plus ship & shifter.
Mike Taylor 3601
no arguement here, it's just all i have at the moment.
the biggest question is can i still shift?
not the trans, ...me.
i AM getting older...but i have NO desire to run an auto....i'm doing this for fun and, honestly, if it ends up being another "job",i'll run brackets (we've got a stick series out here...
Old 02-26-2010, 08:41 AM   #26
tj310
How come manual trans threads draw so many opinions ? With all this ratio talk how would a 2 spd ever get downtrack? ...Thanx Trevor
Old 02-26-2010, 10:18 AM   #27
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Save up buy a Jerico and a soft-lok clutch(Hyatt,Mcleod,Advanced,Ram, etc) and you will be happy. Ed
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 02-26-2010, 02:54 PM   #28
Jeff Lee
Jeff Lee's Avatar
I would disagree with Mark that a stick won't work well because of the weight and low RPM of the car. It's evident in the post he's behind the times and clutch and flywheel technology have come a long way since he had the Pontiac.
On the other hand, I think if one can't afford to do it right (trans, clutch package), then you would save yourself a lot of expensive aggravation if you stayed away from a stick.
Jeff Lee 7494 D/S '70 AMX
Old 02-26-2010, 04:03 PM   #29
Liked 5,142 Times in 1,963 Posts
LOL, I know, Jeff. One call does it all .
Only reason I'm behind the times ,is because I choose to be ,especially with that combination.
Old 02-26-2010, 05:00 PM   #30
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Smile Re: Manual Trans Help
Trevor, you have a PM
Dave Turner
SS/GT #1153
