Old 02-28-2010, 06:05 PM   #1
Robert Swartz
Robert Swartz's Avatar
Default NHRA blueprint guide-part crossover?
Ok, it's cold outside and I'm sort of shut in for now. After beating around the idea of building a combination for one organization versus another in a previous thread. I decided to do some looking myself. I'm pretty committed money and parts wise to building this car for the IHRA crate motor class. If I desire to move the car to NHRA, I want to leave my options open.
I was beating around the classification guide looking up a SBC combination for my 1979 Firebird to run NHRA. Some months back, I bought some shocks off Steve Ficacci. We traded a few emails and he suggested I look at the Chevy 350/165hp engine. This emgine was an option for the Firebird. I was looking for part casting numbers and stumbled across something I found interesting.
This particular engine was also offered in the 1979 Malibu station wagons and as well in all versions of the 1979 Nova. The casting numbers for the heads, #462624 and 376450 show up on both Chevy and Pontiac parts of the guide. Carburetors also appear to have the same numbers. A discrepency I see is the intake manifold, for the Pontiac, it only lists the #1400376. In the Chevy portion of the guide, it lists an alternate intake, #346249. All things being equal, if an item is legal for one combination (the Chevy's), why wouldn't it be legal for another (the Pontiac)? I'm sure a call to a tech director would set this straight. Want to see what those with experience in these matters have to say.
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
Old 02-28-2010, 08:07 PM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: NHRA blueprint guide-part crossover?
Robert,
I do not know about the intake, however, be sure you understand the "factored" horsepower rating is 287. Thus, it can be stated as 350/165/287
And speaking of the Crate Motor combinations, I like them. If you have some IHRA races in your area is is a valid option. In addition, the new AHRA will run the Crate Motor combination in stock, thus, another option.
In that 1979 Firebird, the 350/330/340 Crate Motor with Vortec heads is a stout runner.
Larry Woodfin 471W
Old 02-28-2010, 08:24 PM   #3
Liked 5,139 Times in 1,962 Posts
Get a hold of Wesley Roberson. Explain the situation. Most likely, it's just a typo or an omission. He will fix it for you, without delay.
Old 03-01-2010, 12:10 PM   #4
Bobby Zlatkin
Bobby Zlatkin's Avatar
Robert,
I believe the rotating assembly (short block) is the same between the NHRA 350 stocker & the IHRA crate motor. Only differences; cam, heads, intake & carb.
Someone correct me if I'm wrong.
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
Old 03-01-2010, 02:53 PM   #5
Dragsinger
Bobby,
yes, that is correct. The 350 Crate Motor short block would be the same as an NHRA flat top, four notch piston.
Larry Woodfin 471W
Old 03-01-2010, 04:02 PM   #6
Bobby Zlatkin
Larry,
They are not flat top motors. They are dished piston motors. I believe all 7 IHRA accepted 350 motors are dished piston motors except one.
Old 03-01-2010, 05:45 PM   #7
Mark Lewis
Liked 209 Times in 46 Posts
The crate motor 350 are all flattop 4valve notch pistons. The rule was changed 2years ago.
Mark Lewis is offline   Reply With Quote
Old 03-01-2010, 05:59 PM   #8
Robert Swartz
Originally Posted by Dragsinger View Post
Robert,
Thanks Larry. Yes, I understand about the refactored HP. This is just another option, I'm looking into. My thought is to research the NHRA combo. Then start scratching around for parts.
I hope this crate motor combo will be stout. My plan kind got schewed(sic). I had intended to get the body and chassis prepped first. I've gotten steered more in the direction of collecting motor parts. After purchasing YOUR heads and intake. I've acquired a block and a couple of donor cranks, hope one out of two will be suitable. I've also gotten a set of new Ross pistons. Same guy has a cam and a torque converter I'm going to get as well.
My biggest hangup at present. I'm just lacking a couple decent cash infusions. I'm hoping to, maybe, be able to run a couple combos late this year. The stars are going to have to align just right for that to happen.
