Old 03-13-2010, 05:17 PM   #11
bill dedman
Liked 6 Times in 4 Posts
Default Re: Housing girdle for 8.75"; yes, or no?
Jim,
This little 225 turbo /6 will never see the street.
It's just a hobby/race car.
Would you, or anybody else, for that matter, happen to know what diameter this 170 converter is?
It's still attached to the engine in the car (with the transmission) so, I can't measure it, but I heard it was an 11" converter, just like the rest of them (318/340, etc.)
I'd sure be interested to know.
Guess I'll find out when I pull it out.
Bill
bill dedman is offline   Reply With Quote
Old 03-15-2010, 02:50 AM   #12
GTX JOHN
10.75 with a small hub... be careful all the early 225/170 have a small 1.51 pilot hub instead of 1.66 Hub used on most anything else. Check your crank and converter to makes sure compatible..... also spline count changed to 24 around 67/68 as I recall. Hope this helps... early Mopar stuff is confusing.
John Irving
Old 03-15-2010, 03:02 AM   #13
GTX JOHN
I have cut open and reworked 6 cylinder convertor and used them small bolt and all on my Super Street and Pro Bracket Cars as heavy as 3500lbs even with small 5/16 Bolts. The 6 cylinder and 318/340 converters are both 10.75
Diameter but 6 cylinder converter cover is totally rounded while others all have a flat area around 3/8 inch on top furthest from ring gear... this is probably more than you ever want to know
BTW: Was not on Drinking Binge as some guessed 12/09 to 2/10.....Major Cancer surgery instead as a lot of people already know .....Would have preferred Drinking Binge for sure.
Old 03-15-2010, 02:59 PM   #14
treessavoy
Liked 4 Times in 4 Posts
John Irving
John knows his stuff. The hub and spline change was in '67, anything after that is not compatible with the early stuff without a crank change.
JimR
Jim Rountree
Old 03-15-2010, 03:11 PM   #15
Philip Saran
Liked 14 Times in 11 Posts
Originally Posted by bill dedman View Post
Phil,
We are putting replacement spring pads on the housing, (I know, that's not hangers) and will try to get the pinion angle correct at that time. I said TRY... lol!
Thanks for the advice!!!
Bill, I stand corrected, it is the spring pads that get changed NOT the hangers.
I had a "B" body 8-3/4 housing cut down to stock "A" body width added a back
brace and new spring pads, just need to swap housings in the car.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 03-15-2010, 07:17 PM   #16
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Talking Re: Housing girdle for 8.75"; yes, or no?
Jim, the converter will not last! Even in the turbo 4 cylinder broke the stock type converter with regularity. Dynamic makes some good turbo units. Jim
Old 03-17-2010, 10:36 PM   #17
bill dedman
Thanks to all you guys for the abundance of good advice!!!
I am getting a later (1970) forged crank (with the larger converter pilot hole) and will buy a conveter to match, most likely, from Len Schneider.
I just wanted to save a few pennies on the converter if I could, but as usual, you get what you pay for. I am too old for converter longivity issues...
John Irving; my best wishes to you, and prayers, too...
I lived in the SF Bay area from 1980 'til 2004, and had the pleasure of watching your EXCELLENT 340's run many, many times at Div. 7 races over the years. They have been, and are, an inspiration to me!!!
Hang in there.
Bill
Old 03-20-2010, 04:04 AM   #18
GTX JOHN
Thanks!!
