#31 |
#32 |
well it wasn't a heads up run, and he's not an idiot. A few strokes of the keyboard and I'm sure he can pick it up or slow it down at will, and make it look honest.
Chad Rhodes 2113 I/SA |
#33 |
It's no different than changing jets and timing in your car. The other "tricks" are the same too.
#34 | |
#35 | |
Liked 203 Times in 80 Posts
Mike Fuller 396 STK 3961 SS |
#36 | |
The 08 CJ Can only run AA now. We plan on running the 5.7 to its natural home and I believe that to be B, just an uneducated guess. But were not running 1000 footers, or planning on pulling it in anyway. I know 2 others out there, Doug who has been mentioned and Irv Johns, well I really dont see either one of them laying down. Im not being a prick Im being serious when I ask this, what timeframe would be acceptable to see the HP rated up and to what ? Im curious its a question Ive never asked, I hear that the HP is unfair, etc. but noone I have seen gave and answer to what they think it should be.
Chris "Drooze" Wertman 3132 (F/SA 2009 Challenger Drag Pak #24 with a best of 10.59) |
#37 | |
5.7L should be, at minimum, 385. 5.9L should be around 350. CJ's should be 450+. This is just my own personal opinion based on what (little) I do know about the engines and their respective performances. I think the cars would still be competitive at these ratings, but not dominant like they are now. BTW, Drooze I have no doubt that you'll run the car out every pass.
Jared Jordan 9 B/SA 2024 Jeg's D7 All Star - Stock Last edited by Jared Jordan; 03-30-2010 at 04:43 PM. |
#38 |
Liked 20 Times in 14 Posts
WAaaaaY soft on the CJ
Should be 500 |
#39 |
Yeah, you're right. 450 is soft, but 500 seemed a little stiff at the time.
A rating of 475 would put them about 300 lbs over where they are now. That would level the field but still give them SOME room to show what they're holding back. It's a start anyway.
Jared Jordan 9 B/SA 2024 Jeg's D7 All Star - Stock Last edited by Jared Jordan; 03-30-2010 at 04:42 PM. |
#40 |
Liked 11 Times in 4 Posts
What criteria would you consider the basis of comparison between engines? Ignore the supercharged cars (though I know you can't).
Say that the baseline for A/SA is the 69 427 Camaro. NHRA ratings are 425HP with OEM heads and 435HP with aftermarket heads. This calculates to an NHRA rated HP/cu in ratio of 0.995 and 1.019 respectively. Now the 6.1L - 370 cu in / 385 HP current rating. This translates to a ratio of 1.041 Per the intial factoring this would indicate that the 6.1L engine should produce a ratio of 1.02 times the power of the 427 or 2% more power per cu in displacement than the combo that has been developed for 40 years. Since the 6.1L is blowing the doors off the Camaro's we know this number is higher. I am sure it is true do to better cylinder heads, intake manifold and much larger TB. If there were proportional restrictions made for head port size (well out of NHRA's control since this is base engine design) and TB sizing (something NHRA could have regulated) then these engines could have been more equal from the onset. Bumping this engine all the way to 415 or 425 HP - may be a little harsh, saying that they will outperform the capabilities of the developed combination by 12-15% at their introduction but again there is far too little data to support it not being true either. Not having any data on the combustion chamber efficiencies, pressure drop measured in the ports/intake, its hard to say what the proper ratio of power output per cu in should be when comparing the two different engines. Again there are many software packages that could take data that is already required for blueprinting these engines with a few extra data points for head flows, etc and evaluate the power potential of the new engines and then properly scale them to align to the established combinations.
Tim Kish 3032 SS/GS |
