Liked 335 Times in 182 Posts
Any body work at a Ford dealership???? Need a someone to look up a TSB--technical service bulletin--- for me please--NEED THE TSB ###--- Vehicle is a -2000 F250 Super Duty with the 7.3 Powerstroke Diesel ONLY 97000 miles---supposedly a TSB refering to the bolt s either loosening or backing out completely on the turbocharger housing---when this happens the turbo fins get destroyed because the whole assemply is not containing the impeller correctly----- Need the number please and I'm also trying to find out if MAYBE Ford will cover this ---Seems to occur rather frequently not all that unheard of according to several repair shops I talked to--- Just trying to save $700-1000 dollars if I can get them to fix it under warranty----Thanx Comp 387
The bulletin was released in 2001 and Ford payed for the fix until 1/2003. If you did not recieve a recall or TSB and were the original owner you may be able to get them to help but I doubt it.
Liked 54 Times in 18 Posts
http://www.ford-trucks.com/tsb/tsb.php/m-FORD/y-2000 look on here, never mind, double post
#5 | |
When ever I need to know something about my truck thats where I go.
Art Leong 2095 SS |
thanx guys will check into it on Mon---Comp 387
