Old 04-08-2010, 09:18 AM   #1
wayne hutton
Default valve adjustment - sherman lifters
what process do you use to adjust valve lash on these things, 302 stocker sherman lifters ,screw in stud w/poly locks. The card that came with them said .013 to.015, set to -.005. That was farily easy on the engine stand with dry lifters you could feel the .013 spring deperssion and with a dial indicator on the spring you could collaspe the lifter and backoff the .008 to get bach to -.005. Now the engine has been run and is in the car need to reset lash. The lifter now has oil under the cup, hard to feel the small spring depress and almost impossiable to get to each valve with a dial indicator. ther must a better way to do this.
ps excuse my typos and spelling not much at this keyboard thing
thanks
wayne hutton
wayne hutton is offline   Reply With Quote
Old 04-08-2010, 10:25 AM   #2
Robert Simpson
Liked 20 Times in 12 Posts
Question Re: valve adjustment - sherman lifters
Not to highjack this thread I to would like to know how these valves are adjusted in a sb stocker? TDC, EOIC, turn the pushrod method etc?
Thanks
Robert
Robert Simpson is offline   Reply With Quote
Old 04-08-2010, 10:47 AM   #3
Tim Ellis
Liked 7 Times in 6 Posts
Default Re: valve adjustment - sherman lifters
You think they are hard with screw in studs and poly locks, you should try it with the stock rockers and those #$@%!!! shims! I'm not convinced im even close.
Tim Ellis is online now   Reply With Quote
Old 04-08-2010, 12:34 PM   #4
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Cool Re: valve adjustment - sherman lifters
I set mine with a .002 filler gauge just like you would a solid cam. I'm sure someone will say that's not right but that's how I ran the silver car for years.
Old 04-08-2010, 03:50 PM   #5
7423
Adjustable pushrods with the stock rockers, time consuming but MUCH easier than those shims you are so fond of............................
7423 is offline   Reply With Quote
Old 04-08-2010, 06:25 PM   #6
Jeff Lee
Jeff Lee's Avatar
I highly reccomend the EOIC method and turning the engine over with a wrench, not the starter.
Greg, you will probably find a zero lash, once the set screw is set, will yield .002" which is perfect in my book. I figured that out one day and couldn't believe the amount of time it saved. I had ARP adjusters and all 16 came out perfect. It was far more accurate (after testing with a go-no go method) than trying to get the feel with a .002" feeler gauge.
Jeff Lee 7494 D/S '70 AMX
Old 04-08-2010, 09:23 PM   #7
Robert Swartz
Robert Swartz's Avatar
Acronym alert, EOIC, at the cost of being stupid, what is it?
Robert Swartz - Swartz & Lane 66 Chevy II Pro
95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock
Robert Swartz is offline   Reply With Quote
Old 04-08-2010, 09:37 PM   #8
7423
exhaust opening, adjust intake
intake closing, adjust exhaust
Old 04-09-2010, 03:47 AM   #9
Robert Swartz
Thank you. Was pretty sure it was something simple. I'm going with the Shermans on my crate stock engine. so, this will soon be an issue I need to understand.
Old 04-09-2010, 09:56 AM   #10
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Cliff will tell you, you have to adjust them a couple of times to get them "dead on". I use a .004 feeler gauge and make the first run through as close as possible, setting them by firing order. i start the car, bring it up to temp. shut it off and pull the covers, run through the valves again, by firing order to double check. you may have to "cheat" the lock nut to snug some up. i have never found any too tightm only loose, but it could happen i guess. then after 1 or 2 passes at the track, i pull the covers again for a final check. you MAY find 1 or 2 this time. reinstall the covers and run it. I havent tried the EOIC method on these stocker style engines, but i havent had any trouble either.
Wade O
