Old 04-15-2010, 09:31 AM   #1
Greg Hill
Liked 279 Times in 68 Posts
Default Once again a bogus combination
Examining these crate motor combinations is really eye opening. I did a little research on the 352 Ford crate motor that is in the guide at 285 hp. I compared it to a crate motor that Ford racing sells to the public that is 347 cubic inches and is rated at 450hp.
1. They both have the same heads M-6049=Z304DA. I couldn't find the runner volumes for these heads in the NHRA specs but I would bet they are substantial.
2. The compression ratio on the 352 is 11.25 to 1, the 347 is 9.7 to 1.
3. The cam in the 352 is a solid roller with .575/.575 lift. The one in the 347 is a hydraulic roller with .580/.602 lift.
4. The valve size on the 352 is 2.08/ 1.60. The valve size on the 347 is 2.02/1.60.
5. The throttle body on the 352 is 1000 cfm. The 347 is rated with a 650 Holley that is not included in the package.
Look at the specs. How can the 352 be at 285 if the 347 is less potent and is rated at 450. This is what NHRA and Ford are doing. The 352 is 165 hp less with weaker specs.
Wake up folks. These crate motor cars can run anywhere from AA to M.
Oh and one other thing the runner volumes I just found on Ford racing's own site are 204 cc's on the intake and 85 on the exhaust.
Greg Hill 4171 STK
Old 04-15-2010, 09:36 AM   #2
Harry 6674
Default Re: Once again a bogus combination
Wake up to what? Its no secret. Just like the LT1-LS1 days. It'll all work out it just takes longer with shoe polish.
Harry 6674 is offline   Reply With Quote
Old 04-15-2010, 09:53 AM   #3
Greg Hill
We will all be dead and gone by the time these things are correct.
Greg Hill 4171 STK
Old 04-15-2010, 10:59 AM   #4
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Unhappy Re: Once again a bogus combination
Im with you on this. The older cars and racers (stock and S/S) are "Dead" and dont even know it yet.
Old 04-15-2010, 11:16 AM   #5
Jack McCarthy
Liked 477 Times in 117 Posts
Talking Re: Once again a bogus combination
so greg...
what class does your ford van / truck/ mini van thing fit with the 352 crate motor ???
now that would be a cool stocker even i could like... it's almost a station wagon
jack
sorry i couldnt resit !
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 04-15-2010, 11:25 AM   #6
Jim Kaekel
Liked 535 Times in 110 Posts
After reading the specs. per Greg, it's obvious that Ford surely has a master plan....$$$. Win on Sunday (by using bogus HP factors to spank the competition) and sell on Monday. The sad thing is that the majority of the "fans in the stands" are gullible enough to believe that what they see on the track is what they get at the dealer.
Jim Kaekel 3836 STK
Jim Kaekel is online now   Reply With Quote
Old 04-15-2010, 11:32 AM   #7
XSTOCKER
XSTOCKER's Avatar
Liked 8 Times in 3 Posts
Crate motors and NHRA......priceless!
XSTOCKER is offline   Reply With Quote
Old 04-15-2010, 11:45 AM   #8
Charley Downing
Liked 633 Times in 88 Posts
Greg give it up.
Charley Downing 3548 STK
Charley Downing is offline   Reply With Quote
Old 04-15-2010, 11:54 AM   #9
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
That's exactly what I was thinking...
The crate motors can't run AA-M... they can run A-M/CRATE MOTOR in IHRA!
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
Old 04-15-2010, 12:00 PM   #10
Greg,
The camshaft spec is wrong, it should be .512/.512, just to set the record straight. Maybe you will be gone Greg, but I will still be having fun.
Terry, Stk and SS are dead for guys like you, The numbers from NHRA are higher then ever before for competition numbers in stock eliminator.
You can change with the times or you can dream about the old days. There is no future in the past.
