#11 |
Liked 6 Times in 5 Posts
Thanks for the link Dean. I'd like to see someone do this comparo again with current build filters. Any way you cut it, I'm always and always have been scared of Fram.
#12 |
Liked 1,880 Times in 422 Posts
The PF35L is often found with a perforated steel core. However, the media is too fine for a high flow application.
The oil filter for a Duramax seems to always have a perforated steel core, I have yet to find one without it. I think the number is PF2232. It fits small and big block Chevy engines. Never had a problem with one, either. The K&N filters are good, never had a problem with one, and they can often be found at the chain stores if you need a filter and the NAPA or CarQuest is either closed or too far away.
Alan Roehrich 212A G/S |
#13 |
Moroso 22460.
#14 |
Liked 482 Times in 159 Posts
#15 |
Pure Power.
•American made using certified premium materials.(Beware of inferior knock-offs!) •100% Filtration through T304 Stainless Steel Media •Improved particle removal (up to 90%) •Increased Flow (our smallest filter tested at 20+ gpm) •Lab tested SAE Burst Rate 1,000 psi •Cooler operating temperatures •Easy Monitoring of the engine •Easy Cleaning •No disposal charge •Extended Oil Drain •Used in all major racing venues on land, sea and air •This unique system is the ONLY cleanable/reusable oil filter proven to be so effective and reliable that it passed stringent F.A.A. testing with flying colors http://www.gopurepower.com/ |
#16 |
Liked 27 Times in 10 Posts
Baldwin B253 is a racing filter that was made for Ferrari racing. This is the Mopar Ford filter I don't recall the chevy filter number but can get it and post it later.
#17 |
Liked 520 Times in 132 Posts
WIX 51069R is the way to go.
#18 |
Liked 20 Times in 12 Posts
Thank you guys so it seems that a majority is
1) Wix Racing 2) K&N 3) System 1 etc Stay away from 1) Fram Racing (I agree!!) 2) AC Delco Thanks again for the info |
#19 |
Liked 68 Times in 31 Posts
wix 51069r is the way to fly, napa1069 only if wix isnt available it doesnt have the hi flow
media of the 51069r it is just a passenger filter.
Ron Mattson 5015 STK |
#20 |
Liked 53 Times in 13 Posts
the AC PF-35L is still available at any GM. dealer parts dept... never any problems with it, they come 12 filters to a case only...I have 3 cases at home. I use AC- oil filter on all my cars. BTW AC oil filter is made by Delphi in mexico buy automated machines.. Luke SS311
