Old 06-07-2010, 04:53 PM   #1
racerron5
Default Powerglide problem
Does anyone know what is wrong with a powerglide that all of the sudden started jerking and seeming to be out of gear rather than working normal. The car moves but while moving either seems to be in neutral at times and quits moving or moves but real jerky like. Fluid seems to have a burnt smell to it now. Also can the converter cause this?
Thanks in advance.
racerron5 is offline   Reply With Quote
Old 06-07-2010, 04:58 PM   #2
Default Re: Powerglide problem
The converter might do it. The planetaries might do it as well.
Old 06-07-2010, 06:26 PM   #3
63corvette
Liked 359 Times in 103 Posts
If the fluid smells burnt you have major issues in the trans and converter parts are probably inside the trans if the converter went first.
Drain the fluid and look in the pan first. That will tell you a good deal if parts or gears or just pieces are there.
Just pull it and get started it won't fix itself with those type issues.
Just My 2 Cents And Best Of Luck With The Repairs
Just a part of racing and we have all been there.
63corvette is offline   Reply With Quote
Old 06-08-2010, 01:52 PM   #4
chevy620
Banned
63 is right,
Take it out, it will not be something you want to try to fix with it in car. Be sure to flush the cooling lines before you put it back in.
Good luck,
chevy620 is offline   Reply With Quote
Old 06-08-2010, 02:33 PM   #5
Forward clutch is probably burnt up and slipping.
Not the converter. Either it moves or it doesn't.
Old 06-08-2010, 02:48 PM   #6
The reason I say what I said is this. A PowerGlide has a band for low gear, and clutches for high gear. Rarely do you see either fail suddenly, and you usually just get slippage under power. It will usually slip in one gear, and not the other, and they just won't hold, rather than jerking as described.
The planetaries will fail suddenly, especially the stock planetaries, and more so if the input shaft being used is not a torsional shaft.
The converter could also break suddenly, and broken pieces may cause it to jerk as described, when they bind up. It may also overheat the fluid and make it smell.
Old 06-09-2010, 10:32 AM   #7
racerron5
Thanks for all of the replies. I've had a converter break before and the car would still move so I know that can happen but I don't remember it jerking then. I did take it out but haven't had a chance to look any further yet. Mostly it acts like it's not in gear, then you rev it up and it will catch and move, that's when it jerks and it stays jerky like it grabs then slips then grabs then slips, that's the best way I can describe it.
Only had a chance to try out low and then figured I better stop trying things in case it was making it worse. So it does it in low if that helps at all. The converter looks fine, sprag goes only one way and nothing is inside of it.
Old 06-09-2010, 01:44 PM   #8
Jeremy K
Definitely sounds like what happened to my Powerglide two years ago. It ended up being busted planetaries. Mine drove back the return road and was very rough, but then locked up trying to drive it in the trailer.
Jeremy K is offline   Reply With Quote
