Old 06-08-2010, 08:59 AM   #1
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,379 Times in 502 Posts
Default Best tire for stick car..
I am using Phoenix ph379 13/31 right now but I think they are way too big for my application.
What do you guys recommend for a stick car? Something with a stiff sidewall and medium compound? Or do you know a knowledgeable source for me to contact? Thanks.
'65 Mustang SS/L & L/SA
Old 06-08-2010, 02:28 PM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: Best tire for stick car..
I think the M/T 9x29.5S would work just fine for your application. I still had them on my AMX with Cal-Track parts with the 390 Superstock engine and went 10.0's with 1.38 60' and a 7200-7800 RPM launch. A 289 would be a piece of cake!
But then again I felt the need to re-work my car and for some reason got talked into a pair of 14.5 x 31.5 GY's. Sounds like way to much tire as well.
Jeff Lee 7494 D/S '70 AMX
Old 06-08-2010, 11:58 PM   #3
Cam
Cam's Avatar
Originally Posted by montys 55 View Post
if you don't mind the question do you guys run the M/T bias without tubes
I don't run tubes with the 9X 29.5S M/Ts. Since the tubes came out, no more flat tires
Cam Chowen
6067
1994 Camaro C/S
Cam is offline   Reply With Quote
Old 06-09-2010, 12:02 AM   #4
Stephen & Horace Johnson
Liked 163 Times in 53 Posts
I put a set of MT stiff sidewalls on my daily driven mustang and picked up .06 in my 60fts. Its a stickshift but i run a 28x10.5in slick. 10.70s N/A
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 06-09-2010, 12:20 AM   #5
Jeff Lee
Jeff Lee's Avatar
No tubes.
Old 06-09-2010, 07:10 AM   #6
Bobby Fazio
I am not running tubes in the Phoenix right now.
Old 06-09-2010, 05:00 PM   #7
Brad Zaskowski
Brad Zaskowski's Avatar
Liked 130 Times in 20 Posts
Mickey thompson 3072 Bias ply no tubes. You will be very happy.
Brad Zaskowski 3697 STK, SS
Brad Zaskowski is offline   Reply With Quote
Old 06-11-2010, 09:59 PM   #8
Keith Bennett
Keith Bennett's Avatar
Liked 70 Times in 36 Posts
Send a message via MSN to Keith Bennett
Brad,
What is the 3072 tire size and compound?
Keith
Keith A/S 2990/Terri A/SA 2991
"Imagine what you'd attempt, if you knew you could not fail!"
Keith Bennett is offline   Reply With Quote
Old 06-14-2010, 03:04 PM   #9
Evan Smith
Liked 115 Times in 5 Posts
I swear by the M/Ts 9x29.5 ST on my Stocker. No tube and they last 75 runs.
Evan
Evan Smith 1798 STK
Evan Smith is offline   Reply With Quote
Old 06-14-2010, 06:59 PM   #10
Brad Zaskowski
3072 13x31 M5 compound 98 rollout. We run this on both of our SS cars.
The 9x29.5 ST is what we run on our stocker and it works great too.
