Old 06-15-2010, 11:17 PM   #1
Lonnie Cox
Smile Pinion angle
Hey guys
I am building a 76 camaro, K/SA 350cid,turbo 350 275 1st,10 bolt with 4.56 gears,stock springs,should weigh 3775, what should my pinion angle be,
Thank You for your help
Lonnie
Lonnie Cox is offline   Reply With Quote
Old 06-16-2010, 12:08 AM   #2
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Default Re: Pinion angle
-2 degrees( that's a ballpark figure). you running "slapper bars" or Cal-Tracks? also what size tire you going to run?
Old 06-16-2010, 06:21 AM   #3
Billy Nees
If you're using regular "slapper" bars you're going to want more than 2 degrees with that much gear and that much weight. I'd try about 6 degrees! You can better control your angle with a "cal-trac".
Billy Nees 1188 STK, SS
Old 06-16-2010, 08:39 AM   #4
Lonnie Cox
Smile Re: Pinion angle
Tire is a 30 tall,cal tracs some day .
Old 06-16-2010, 09:13 AM   #5
Liked 1,892 Times in 423 Posts
Don't wait, get the CalTracs ASAP. Buy the springs, too. Fighting a car that doesn't work well is far worse than fighting a car that is a little down on power.
