#31 |
Banned
Liked 235 Times in 110 Posts
[QUOTE=Billy Nees;195806]Its nice to day dream and BS about it but what does it take to get it done? I dont have any "pull" anymore and NHRA wont listen to anyone or their own committie so what can you do? Build your combo with the lower valve spring pressures to make it less expensive, get more runs and run slower or just keep on spending the big bucks for the trick of the week, rebuilding them every 75 to 100 runs and/or blowing up very expensive engines I guess.
#32 | |
Banned
#33 |
Liked 7,864 Times in 1,750 Posts
Take away an engines ability to rev and it will be less likely to hurt itself. NHRA is looking for ways to cut down on "down time" so it would seem to just be a common sense rule. BUT I did say NHRA and common sense in the same sentence didn't I? Isn't that like saying Military Intelligence?
#34 |
OHC engines use very little valve spring pressure. They don't need it.
#35 | |
Liked 783 Times in 195 Posts
#36 |
Banned
I remember when I got my brand new 68 Z-28 I could sling it to 7000 RPM easy and I never had the valve covers off yet to shim the springs and lash the valves. The springs had to be around 70 lbs on the seat or close to it. I did pull 4 studs (68s had pressed in studs) one evening (car was 2 days old) due to a missed shift with the OEM clutch sticking to the floor at 7000......lol. Probably lucky I still have my legs as I still had the OEM cast flywheel and no scatter shield yet. Dumb ***** attack on my part.
#37 |
The trouble with setting a specific # for valve springs in this day and age is that the cam manufacturers are building cams that a flat tappet lifter just can't follow even with the best springs! I believe that some of the really sharp Stocker engine builders are actually getting away from "square" cams and going back to "softer" lobes at least on the exhaust as they're finding they're "cleaning up" the intake charge by not bouncing the exhaust valve around on the seat. Think about what the "harmonics" of that exhaust valve bouncing on the seat is doing to the intake charge not to mention the cylinder pressure.
Another good reason for "softening" the lobe is simply to use less spring. Heavy springs just "tie up" horsepower that can't be used to accelerate the vehicle. I guess where I'm going with this is that as much as I'd like to see a "valve spring spec" rule put in the book it would make a lot of cams in use today unuseable and I don't forsee any of todays Stocker engine builders or cam manufacturers lobbying for a rule that will make their stuff unuseable. But these are just the ramblings of a bored, crazy old fool living on a hill in Pennsylvania.
#38 | |
Banned
#39 |
Liked 16 Times in 11 Posts
Terry, You need something to do.......I know, you can join the hunt for the 25 foot python seen in your driveway last month. Billy Chupacabra was seen in the area of your Hilly home, be careful at nite they sniff out empty beer bottles left about.
Bob Pagano A/SA |
#40 |
Banned
Yeah...Im bored. I already shot a snake in my yard a couple of weeks ago.
