Old 07-29-2010, 08:27 AM   #41
Paul Ceasrine
Liked 10 Times in 10 Posts
Default Re: If You Could go Back In Time, and Design One Performance Car.
BlueOvalralph,
I also think, that Canada was the only country that got 1965 Ford Falcon Sedans
with 289/271 HiPo engines. (7 produced)
Not K-Code, but #992 Code (Special Order)
Top-Loader 4-speed, with 9" Detroit Locker and 4.57 gears.
With 8" slicks and a few suspension tweaks, you could get all
4-wheels off the ground, when launching off the line.
Damn things ran in B/Stock in 65'
I wonder if any got the 306HP Shelby conversion, with the aluminum DP intake,
and Holley 715cfm carb, and High Compression pistons.
pc
PC
Old 07-29-2010, 03:26 PM   #42
Dick Kirkpatrick
BlueOvalralph,
pc
PC
These were built by Ford of Canada when John Phillips was in charge of special events for Ford of Canada.
Of the seven, I know where some of them went.
3 were made in to B/FX cars, equipped with 4 weber 48IDA carbs, usually heads ported by Crane with Corvette F.I. valves. Most ran the Crane R-292 roller cam with flat top pistons.
The B/FX cars:
Rankin Ford, London , Ontario, "Wild Child" engine by Gene McCrikkard (sp) at the Hot Rod Shop, Detroit, Mich. (same shop that built Doug Nash Mercury Comet B/FX car.
Beatty and Woods, Toronto, Ontario
Don Havers "Mr 289" built by Brad Francis and myself
2 of the 271 HP cars were campaigned in B or C stock, one by Louis Rivait from near Windsor, Ontario and another by Bob Jezzico from Woodstock, Ontario.
Louis Rivait's car ran extremely well.
Dick Kirkpatrick 3033 SS
Dick Kirkpatrick is offline   Reply With Quote
Old 07-29-2010, 11:49 PM   #43
bill dedman
Liked 6 Times in 4 Posts
A 1964 Barracuda with a 1964 Stage III Wedge 426 S/S powertrain, including a 'glass front end, lightweight seats, a 4.88:1, 8.75" rear end, Stahl headers and a parachute...
Bill
bill dedman is offline   Reply With Quote
Old 07-31-2010, 08:19 AM   #44
Paul Ceasrine
Bill,
Probably run 10.50's @ 130 mph.
Would have been what class A/MP, A/FX, A/G?
pc
Old 07-31-2010, 02:21 PM   #45
Run to Rund
Liked 56 Times in 29 Posts
70-72 Olds 442 with W43 (hemi, 4 valves per cylinder) either pushrod or DOHC version. ot Rod and HiPerf cars wrote up the engine in July 71. GM Mismanagement killed the engine project.
