Liked 239 Times in 79 Posts
HELP!
I need a little help w/ figuring IHRA hp and weights: what is the hp and weights for the following: 1. 98 Pontiac firebird (350 lt-1) hp? weight for SS/JA? SS/KA? 2. 99 Pontiac firebird (LS-1) hp? weight for C/FIA? B/FIA? is there a hp advantage for the flat hood? if so, what is it? Thanks in advance; as I could not seem to find a classification guide, |
#2 | |
Banned
Liked 235 Times in 110 Posts
I am pretty certain that IHRA rates both the ram air hood and flat hood the same, for stock anyways. Mike
Liked 208 Times in 45 Posts
Dean,the lt1 is 275hp for ss with a weight of 3195 for ssja, not sure about stk, but I believe the weight for b/fia is 3095.
Mark |
Dean,
LS1 in a 99 bird w/auto is 342 hp in stock. I believe this rule is new for IHRA in 2010, but nonetheless if there is a difference in rating between the ram air and flat hood, you have to take the higher hp rating regardless of hood you are running. Hope this helps... Clint Blezien |
Clint:
thanks, i just read that hood statement last evening ![]() any idea on weight for B or C/FIA w/ LS-1 (IHRA) i can not find classification guide? Mark: Thank You! SS/KA weight w/ an Lt-1 for IHRA? gonna be awful heavy for J Thx, Dean |
LS1 /auto Firebird
B/FIA = 3248 lbs C/FIA = 3590 lbs I'd double check the numbers at tech inspection but im pretty sure they are accurate. Best of luck! Last edited by Clint; 08-27-2010 at 09:33 AM. |
Banned
Check with Hank Blankenship or Danny Waters Sr. at Budds Creek this weekend if you are there. They are good guys and will help. Im sorry but I dont have my books anymore to keep up with the HP factors, etc.
thanks guys!
