Liked 231 Times in 107 Posts
Did any combo's receive hp after Indy?
Banned
Liked 235 Times in 110 Posts
Yes but not enough !
Liked 502 Times in 91 Posts
I'm sure that they will pick up the HP that they lost to the NHRA's new factor numbers with cams and or piston changes. They are just screwing with computer tunes now, just wait. I'm sure that those engines haven't been stroked the .013 that you are allowed along with lighter pistons and all the other crap you can do to a "STOCK" engine. Give them some time and I'm sure that the one's that are going mid 9's now in stock, will be going low 9's or into the high 8's.
Casey Miles 248H Stock? |
Liked 532 Times in 109 Posts
I have not seen where they have made a single change yet. I just checked the 2010 Ford classification sheet and it hasn't been changed. We can only hope that the cars in question get hit with a decent amount of HP, although I'm sure they won't get hit with what they deserve.
Jim Kaekel 3836 STK |
#5 | |
Banned
Jim,
The 2010 352 Ford got 10 ... none of the other Ford combos went 1.25 under, so they won't get HP till the end of the year ...
Chuck Beach 3340 STK |
It seems that I remember Chris "Drooze" making the prediction here quite a while ago, that these cars could get into the eights, and he got ripped up, down and sideways for saying it....
Wonder who is smiling now? And as some of you all suspect, and some even forecast, you "aint" seen nothing yet... David The New Hemi Guy |
Chuck:
Where do you see that listed? I just checked the 2010 Ford classification sheet and it still shows the 352 at 285.
Jim,
You need to 'clean up' your PC. Do the following periodically to keep your PC clean .. Go to start Select all programs Select accessories Select system tools Select disk cleanup Under disk cleanup I would check the following if it applies: 1) downloaded programs 2) Temporary internet files 3) Office webpages 4) Recycle bin 5) Temporary files 6) Web/Client publisher temporary files 7) Temporary offline files Click Ok, then when it is done, go back out to the NHRA website and re-open the spreadsheet.
or hit CTRL and REFRESH at the same time and it will reload the page instead of using the cached...
Jason Goldsack - 1997 Track Champion - St. Thomas Dragway 1997 Race of Champions Winner - Indianapolis, IN Div. 3 finals Last edited by JSLRacing; 09-09-2010 at 07:13 PM. |
