Liked 275 Times in 76 Posts
With new bearings is having the pinion preload at 12-15 in/lbs too light? This is without the seal installed yet, and a solid spacer. 25 in/lbs is what is recommended for a street gear with new bearings. Any thoughts or recommendations would be appreciated.
Thanks Sean
Liked 99 Times in 60 Posts
Sean,
my method for the pinion is to have almost no preload, just barely have the slack out. Never any problem in a wide range of applications and performance levels. The side bearings will have slightly more preload, the shims will require a light, tap. tap, tap to install. When completely assembled the gear set will be very easy to rotate. |
Liked 308 Times in 103 Posts
What Dragsinger said, if want to measure most rears factory spec is around 40'' lbs.
I usually go by feel like dragsinger a good example is have slight drag like front wheel does,as long as you have enough preload that you have no slack up& down you should be fine. Mike Taylor 3601 |
Thank you, Dragsinger, and Mike.
I am glad I asked. Sean
Liked 11 Times in 8 Posts
!2-15 inch lbs. is fine you absolutely have to have SOME preload on the bearings, without it the pinion is free to move. I try to get 20-35 in. lbs total turning torque on race rears. Joe
Joe Buchanan SS/BX 3117 |
You won't have to worry,Sean. After a few launches with a stick car,it'll be loose anyway
Thanks Joe and Mark. Its done and back in the car.
Much better than what I saw with the gear set I replaced. All of the pinion teeth had stress fractures and were ready to let go! Sean
