#21 |
Liked 320 Times in 102 Posts
A few years ago I spoke to Mr. Lang about allowing head studs in Stock Eliminator, he responded by saying that they would increase the cost of building a racecar. The difference between head bolts and head studs is about $40
I responded that by using head studs, the frequent replacement of blocks due to pulled threads from stripped head bolt holes could be reduced. My request fell on deaf ears.....but in NHRA's world it would make sense to allow Ti valves in Super Stock Once it became optional, it would become mandatory due to a performance increase Go figure
#22 |
Terry: ok stock appearing intake manifolds
Tony Janes 7941 STK, SS |
#23 |
Banned
Liked 235 Times in 110 Posts
#24 |
Liked 1,829 Times in 414 Posts
Yeah, we need $60 a piece valves, and another 1000 RPM, added to a class that hasn't seen a purse increase in a decade, and has seen the contingency payout drop by around 50% in the last 2 years.
![]() It's time we stopped the frikkin escalation in the sportsman classes. It has long since gotten way out of control, with stuff we don't need that has only made the racing way too expensive, and hasn't improved anything. As a long time Super Stock racer said a while back when I was in his shop, "The sorry SOB that gave the okay for ported and polished heads in Super Stock ought to have them all stuck where the sun never shines". And yes, we're going Super Stock racing. The car should be on the track in 3-4 weeks or so. ![]()
Alan Roehrich 212A G/S Last edited by Alan Roehrich; 09-15-2010 at 07:50 PM. |
#25 |
Liked 88 Times in 28 Posts
Geez, the damn bitchen that goes on, maybe stock should mean real stock, as in pure stock.You know, pure stock as Terry wrote the rules for. Then maybe the average guy could afford it. Or as NHRA says " Entry Level" Just my 02 Pat.
#26 |
Liked 44 Times in 27 Posts
#27 |
#28 |
Liked 140 Times in 51 Posts
#29 |
Liked 27 Times in 4 Posts
titanium valves WTF, Where the hell does this stop? Chamber mods, aftermarket cranks, etc etc. Why change the rules to accomodate those that do not follow them [ cheaters]. Titanium valves are already in use like the cranks and chamber mods were before becoming legal to do so. Throw the cheaters out rather than change the rules for them. Why stick it in everyones ***** that does the right thing. NO TITANIUM VALVES ! This is SUPERSTOCK not prostock. Oh but we need change, look where our change is gettin us. Leave the rules as they were written.
#30 |
Liked 7 Times in 4 Posts
I cant stand it anymore
The simple solution is to implement the valve spring rule-period! Stock spring pressure. There would be no 9800 rpm hemis or 9800 rpm anything else. IMO this was the downfall of stock. Lower rpm no acid heads or manifolds needed. No $1000 lifters no $7500 heads. Wouldnt matter cause they cant flow at lower rpm. Just my 2 cents
Jess Suter 7305 Stock/SS Duster "life is not a rehearsal" |
