Liked 55 Times in 17 Posts
Any opinoins on merge collector vs. standerd collectors...are they worth the $$$$
Joe, to make a long story short, if your primary tubes are too big then a merge collector will help you. If they're too small or just right then they will hurt.
thanksbill you deserve a hot dog or burger
Liked 4,379 Times in 502 Posts
Joe, we had long merge collectors on our car at the beginning of the season (our headers are 1 7/8 tubes which I believe to be too big for our application). We switched to a smaller, inexpensive edelbrock merge collector from summit, and it picked up the ET and MPH. I also searched these forums many times to read everyone's opinion on the subject and couldn't find a solid yes or no.
Liked 1,893 Times in 423 Posts
There is no definitive answer to this question. Whether or not you can gain from a merge collector depends on a large number of factors, each combination is as individual as the person who owns it. It is impossible to say for certain if merge collectors will help a combination without knowing nearly every individual part involved in the combination. And then if you change one or more of those parts, you start all over again.
Alan Roehrich 212A G/S |
Liked 3 Times in 1 Post
Call Mark at Performance Welding. He will tell you straight out if he thinks it will hurt or help your combo. He builds and sells them, but, has also told people what they have is sufficient.
Wade O |
X2 on Mark... he has the benefit of doing a fair amount of back-to-back dyno testing of his headers, tons of variations on complicated eliminator V8's. He also does an outstanding job of custom header fabrication, the stainless stepped header he made for my car is over-the-top
Liked 165 Times in 59 Posts
the only real way to find out if the merg collectors are a gain or loss is the dyno,,this wil give you that info but you cant take the dyno for a pass down the track ,,,i picked up just a 2-3 hundreths by adding them but i also built a set of step headers as well ,,lots of laps is the only way to realy see a consistant gain or loss gmonde
