Old 09-19-2010, 11:21 AM   #11
TimKGillespie
Liked 38 Times in 9 Posts
Default Re: TH 400 vs 350 vs 200 metric
Marvin...you have a PM...
TimKGillespie is offline   Reply With Quote
Old 09-20-2010, 06:59 PM   #12
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Forget the trans, it's worth 0 the converter can swing you 3-4 tenths!!!! I strongly advise using a BOP converter specialist. Stock eliminator converters will NOT work in a Olds 455.
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 09-21-2010, 12:48 AM   #13
Todd Hoven
Guest
Posts: n/a
Thats not true, you just need the right converter by the right company. The wrong converter is worth 3 10s the wrong way. Don't waste your time putting aluminum drums in a 400. Buy a good 350 or the right 200. A 200 will live fine behind a 455 if you have the turbo input converson, with a good pump and stator support.
Old 09-21-2010, 10:05 AM   #14
junior barns
Liked 20 Times in 14 Posts
Any recommendations on the "right converter" company??
junior barns is offline   Reply With Quote
Old 09-21-2010, 02:05 PM   #15
Todd Hoven
Guest
Posts: n/a
Frank Lupo fron Dynamic has been supporting me for years, and also Lenny Williams. Both pretty good cars. Lenny from Ultimate has been working with Johnny Williams (OLDS 455 car), and his car runs very good as well.
Old 09-21-2010, 02:12 PM   #16
Jim Kaekel
Liked 535 Times in 110 Posts
Marvin: I've got a TH-350 in my car, and have had great luck with both ATI and A-1 converters.
Jim Kaekel 3836 STK
Old 09-21-2010, 02:27 PM   #17
Marvin Robinson
Marvin Robinson's Avatar
Jim,
Thanks for the input, I have an ATI converter right now, and will stick with them for the time being... I'll see where I'm at when I test in the spring (the 455 is being redone, found major issues when I tore it down after wiping a cam lobe @ Gateway).
Marvin Robinson
3188 STK/SS
Marvin Robinson is offline   Reply With Quote
