Old 09-26-2010, 09:59 PM   #11
John Leichtamer Jr
John Leichtamer Jr's Avatar
Default Re: Hemi Super Stock Challenge @ Hebron (SPOILER)
Piston dome not rite to much .002
Hammer
John Leichtamer Jr is offline   Reply With Quote
Old 09-26-2010, 10:16 PM   #12
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Question Re: Hemi Super Stock Challenge @ Hebron (SPOILER)
Hammer
????? I always C.C.ed a Hemi S/S dome down in the hole (105.2 C.C.s for a race Hemi) as its an "above block" spec. engine or any other S/S engine dome or dish for volume. I measured STOCKER pistons dome/dish with various gages (usually a dial indicator with a bridge) as they are checked differently than S/S. Whats changed?
Old 09-26-2010, 10:58 PM   #13
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
You are correct.
Old 09-26-2010, 11:25 PM   #14
X-TECH MAN
Banned
Cool Re: Hemi Super Stock Challenge @ Hebron (SPOILER)
Originally Posted by JSLRacing View Post
P-G a motor?
A P&G gauge is like an air pump gauge graduated usually 1 to 100 in 1/4 increments like a CC tube or more depending the range of the guage. . You screw in a fitting into the spark plug hole of one cylinder. After making the rocker arms of that cylinder inoperatable so both valves stay closed you spin the engine with the starter with the fitting connected to the P&G by a hose. The reading you get on the "pump" from a puck sliding up a glass cylinder gives you XX as a reading. Add a % of factor for the temp of that cylinder measured with a thermometer and listed on a chart supplied with the P&G gauge. Then you mutiply times the number of cylinders 4,6, or 8 to get the cubic inches. They usually measure 1 to 3 cubic inches UNDER the true size of an engine IF done correctly unless it spins to fast because of a16 volt starter systems. If the figure is OVER the claimed cubic inches then either you did something wrong or its time to pull the head and physically measure the engine. Thats about as good as I can explain it on this forum. Its eaiser to use and show someone how to do it than explain it here. A P&G is not "dead on" tool but a good indication if someone is cheating or not on the size of the engine claimed. The inspector should always make sure the fitting used is the one supplied as Ive had guys try to slip by by changing fittings with a "Bleed hole" in a fitting they have and THAT would give you a false reading. I wont mention names here but I can tell you it was usually a Pro stock racer from the good ole days....LOL and it was tried at an NMCA race years ago by a well know 409 Chev. engine builder. Ya gotta keep an eye on everyone.....LOL.
Old 09-27-2010, 10:57 AM   #15
Crew Chief
Liked 10 Times in 6 Posts
The word that spread through the pits was too much piston dome.
Crew Chief is offline   Reply With Quote
Old 09-27-2010, 11:17 AM   #16
X-TECH MAN
Banned
That would have to be C.C.ed as I stated before because it is a S/S classed engine during tear down. Its not a very easy job to do in the car but can be done quite accurately if careful. If it was a stocker Hemi being checked (not this car) then the piston would be measured with a dial indicator or similar precision tool from the deck of the block at TDC for the clyinder to be checked.
Old 09-27-2010, 12:05 PM   #17
Bobby DiDomenico
Liked 101 Times in 52 Posts
Originally Posted by SPS View Post
Not correct.
The car didn't stage or go over the scales.
There is no winner.
Happened to me and Fadely once for class. I got disqualified and he didn't go over the scales. Neither got the win.
Tech guys messed up, I guess.
FJ
This is what we've been told occurs, you cannot win above your last pass. Tough deal for both.
Old 09-27-2010, 08:44 PM   #18
Barnstorm
Barnstorm's Avatar
What's the consensus on wha t happend? Daniels or nobody?
Old 09-27-2010, 09:34 PM   #19
Stewart Way
Liked 70 Times in 22 Posts
Rulebook is kind of clear. Page 2.2 under staging,,,"To be a legitimate race winner, a contestants vehicle must self-start and self-stage.". Sounds like you at least have to stage.
Stewart Way 2424 SS
Old 09-28-2010, 12:42 AM   #20
BobOrme
This is strictly my own opinion. I don't know if such a situation is covered in the policies and procedures manual that covers stuff that happens that isn't specified in the rule book.
If the violation was one that could be something like fuel or weight that, for what ever reason, only happened in that single round, it wouldn't necessarily indicate that the car wasn't legal for the entire event. An engine spec violation could. That could also lead to a belief that Pancake was in violation of the rules in round one. Therefore, awarding Daniels the win by just making it to the final round would be fair.
BobOrme is offline   Reply With Quote
