I've got a really nice Small Journal 327" block that I want to build into a 350" or bigger... Whats out there and avail?
Thank You in advance!! Larry
Larry Fulton |
Liked 8 Times in 7 Posts
Put a 283 crank in it and have fun!
Jeff Lee 7494 D/S '70 AMX |
Jeff, Great Idea, I did a 302 for a customer of mine last year with a .650 lift roller, some Dart Heads, and a Tuned Port Injection set-up. It runs on E85 and sounds like an Indy Car. It is in a 67 Camaro Street Car with a flat hood and 4-speed. Fun car.
BF/S 1985 Grand Am 3.0 V6 |
Liked 354 Times in 120 Posts
If I remember right will the big joural crank swing in a small journal block with out a lot of grinding, some 283 s won,t take a 327 crank.
Tom Meyer 5240 SS Stock ??? |
Liked 780 Times in 194 Posts
I don't know if there is a readily available small journal aftermarket crank with that stroke. It is not difficult to have a 350 crankshaft machined to fit. If you do that, you could then use small journal rods to make the historically infamous "9/16 stroker" and make 368 cubic inches. Tom Meyer is correct, you should check clearance in the crank case before you start assembling.
#8 | |
The first 295HP / 350" in '67 were o.e.m. assembled Small Journal Cranks... It wasn't until jan / feb '68 production that GM went to the Large Journal 350"... Dwight, is my memory correct? (I'm done with the 283" stuff / just sold the 721 blocks, cranks, etc that I had been sitting on forever) Thanks again! Larry
Larry Fulton |
#9 | |
Liked 1,929 Times in 580 Posts
Mike Pearson 2485 SS |
#10 | |
Larry Fulton |
