Old 10-23-2010, 06:08 PM   #1
Stocker
Default Q-Jet parts
I have the 1-20 thread adapter fitting #6 AN, on my Q-Jet. Is there common practice to use 1-20 thread #8? If yes,is there a part number to order these fitting with #8 AN ?
Thank,
Stocker is offline   Reply With Quote
Old 10-23-2010, 06:26 PM   #2
Danny Ashley
Liked 110 Times in 29 Posts
Default Re: Q-Jet parts
Yes and use Russell # 640350
Danny Ashley is offline   Reply With Quote
Old 10-23-2010, 06:28 PM   #3
FED 387
Liked 333 Times in 180 Posts
Jegs sells part #555- 100501 $9.99 for the -8 they also sell a -10 fitting go to the Jegs site put in the part number lots choices---Comp 387
Old 10-23-2010, 06:32 PM   #4
FED 387
By the way I believe it is a 7/8-20 size---Not a 1-20---Comp 387
Old 10-23-2010, 07:45 PM   #5
Ron Miller
Liked 13 Times in 7 Posts
Were you considering a # 10 to a Q-Jet fitting. If so contact John at Product Engineering and ask for PE 3510 -10 A.N. x Quadrajet. The cost is around $ 15.00 plus shipping. John can also custom design and make just about anything you can dream of.
Ron Miller is offline   Reply With Quote
Old 10-24-2010, 11:43 PM   #6
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
All Edelbrock carbs and 74-89 OEM carbs use 1" X 20 thread.
A simple fix is to drill and tap your factory inlet housing to 3/8" pipe. With a good drill press and a sharp tap it won't take you more than 10 minutes. Then you can use a very common AN to pipe adapter.
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
Old 10-25-2010, 06:29 AM   #7
STOCK1278
STOCK1278's Avatar
Made mine. drilled and tapped the -6 fitting, thread in the -8. No problems
Jason M Silver
NHRA Stock Eliminator - 1278
88 Oldsmobile Cutlass 307/213
STOCK1278 is offline   Reply With Quote
