Old 11-09-2010, 02:30 PM   #11
Jeff Lee
Jeff Lee's Avatar
Default Re: Effects of weight removal
Originally Posted by Adger Smith View Post
Jeff,
I think one of the reasons my car doesn't like the wheelie bars is the extra 15 lbs of unsprung weight they hang out on the rearend. That has to cause unwanted issues with shock and spring control. I proved my point by raising the bars and not even letting them touch the ground.I can see your improvement with the less spring weight.
Wade,
Good idea about extra springs.
One of the reasons I had those AJE bars on the car. Very light. But now illegal.
Jeff Lee 7494 D/S '70 AMX
Old 11-09-2010, 03:12 PM   #12
Dick Butler
Liked 32 Times in 19 Posts
Guys, Softer rear springs dont just lower the rear end they allow more travel on separation depending on Shock adjustments. Same with front. More compression at rest more length and push on leaving.
60 ft with 52front 48 rear can work by 4 link length and angle adjustments too. Try the lay out of the bars and use that as a map to work through the positions and record what the car likes....You can have TOO much down force which slows also.
Old 11-10-2010, 11:08 PM   #13
Alan Warman
I would like to think everyone for all the info, I will put it to good use. Also another problem I am having is to much anti squat, mine is at 142%. Would the car work better if I lower it to 100 or 120%. The car is a 85Olds G-Body with a 307 Olds motor no HP or TQ.
Alan Warman
STK 4107
Alan Warman is offline   Reply With Quote
Old 11-11-2010, 12:12 AM   #14
Liked 5,125 Times in 1,953 Posts
Originally Posted by Alan Warman View Post
Well, the season is over and time to make some changes to the car. I run J/SA and my minimum weight is 3170 lbs, but my car weighs 3225 lbs with me in it and no ballast. The weight distribution is 57% front and 43% back, not that good but it could be worst. The good news is that I can remove 105 lbs off the car with 85 lbs coming off forward of the front spindles. The bad news is that it will cost about $1500 dollars or $15.00 dollars a pound. What I would like to know is, will you see any improvement in your sixty foot or ET by changing the weight distribution. Lets say going to 54% front and 46% rear.
Question, Alan
Looks like those cars will make K or L. Why not go there, if you're worried about not enough weight on the rear axle?
