Old 11-12-2010, 08:22 PM   #11
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Cool Re: deck height:
Originally Posted by art leong View Post
I believe it was changed in 98 or 99.
I'm not sure but didn't the questionable rockers have the ratio stamped into them?
I believe the ones that were caught earlier this year were stamped but NHRA was aware of this trick for years when one of Warrens 350 Camaros was found to have Crane 1.6 rockers on it and using an undercut cam to make the lift check right. It changed the opening speed of the valves more than anything.
Old 11-12-2010, 08:41 PM   #12
art leong
Default Re: deck height:
On the old Challenger we would shim the rocker stands to get the cam to check. It would change the geometry. I would think there are to many variables. If they check the lift at the cam there is no push rod flex ETC. And that can make a diffence especially with todays valve springs.
Art Leong 2095 SS
Old 11-12-2010, 11:34 PM   #13
Jeff Lee
Jeff Lee's Avatar
One the one hand it seems senseless to hash over this but on the other, my comparison to valve lift makes sense. Well at least to me...
If NHRA has a spec indicated in their books (deck height / rocker ratio) and in the end all they care about is a minimum volume between the top of the piston @ TDC & the chamber and a valve measurement @ maximum valve lift, then why publish the deck height or rocker ratio?
My way of learning NHRA class racing engine blueprinting is if NHRA gives a spec, it is to be adhered too. Not "adjust according to what is convenient". Man, I've spent some money on OEM rods (before after market rod acceptability) adjusting the big end to obtain the exact deck height I desired.
Now I'm wondering why NHRA publishes anything more that the throttle blade diameters on a carb.
And if NHRA specs a positive deck (say a 383 mopar) and I run a negative deck instead, I can save on possible piston to head interference issues and I can probably run a tighter LSA for more power.
Jeff Lee 7494 D/S '70 AMX
Old 11-13-2010, 08:37 PM   #14
art leong
Jeff how confidant would you be with a zero deck height spec? Can you be sure the bearing didn't wear a bit, or the rod didn't stretch a touch? And as far as piston to head problems won't a thicker head gasket achieve the same thing?
If you can't build in a little safety margin you are going to get tossed for stuff that won't help performance one bit.
Art Leong 2095 SS
Old 11-13-2010, 09:40 PM   #15
Jeff Lee
Jeff Lee's Avatar
Then pull the deck height spec out of the books. Just list a tolerance for gasket and deck height combined.
I'm at a loss to figure out how all those zero deck engines made it through tech for 35+ years before NHRA changed this rule. Guess those old engines did not have bearing wear or rod stretch?
Still trying to figure out why a rocker ratio is so important when using this issue as a comparison.
Old 11-14-2010, 11:10 AM   #16
art leong
It was a stupid no common sense rule if the piston was specified to be .001 down the bore if you were 1 inch down it would be fine. If the specification were .001 out of the bore 1 inch out would be legal. What purpose did the old rule serve?
It wasn't a problem as long as there was more clearance than less. Till I drove my car to Maple Grove, set the record with a motor that had never had a head removed. And had .034 to little deck height. Then curt leshure had a problem, and I had a bigger problem.
As far as tolerance goes my motor had 134,000 miles on it was never out of the car (or had the head off) and it was .034 from the stock (listed) specs.
And on some motors adjusting the rod length is not possible.
Art Leong 2095 SS
Old 11-16-2010, 10:30 AM   #17
Adger Smith
Liked 880 Times in 311 Posts
This is the exact quote of the rule about deck height out of the 2006 NHRA Technical Policies & Procedures
I don't think it has changed any since 2006. .
1.2 ENGINE BLOCK
1.2a STOCK AND SUPER STOCK
The deck dimension of the engine block can be either in or out of the block, provided that the
difference in the compression is made up with the cylinder head gasket. Example: if the spec is for
.002-inch deck and .020-inch gasket, and the actual measurement for the engine is .005-inch positive
deck, then a gasket must be at least .027 inches. The opposite is true if the deck is below the block on
an above the block spec, then the gasket may be thinner to the allowable total dimension.
Adger Smith (Former SS)
