Old 11-24-2010, 12:18 PM   #21
Run to Rund
Liked 56 Times in 29 Posts
Default Re: Steel vs Aluminum driveshaft
Aluminum shafts are illegal in most stockers, not steel. Some at yellow bullet swear aluminum gives them a few hundredths. My guess is that if you run a thick wall, long 4" steel shaft, there could be some gain with aluminum.
Old 11-24-2010, 01:32 PM   #22
Bill Edgeworth
I don’t think you can really make a blanket comparison between steel and aluminum drive shafts. Beneficial to some not to others, there is a lot of things to consider when swapping them out and seldom are the new and old physically comparable. One would first think that if its lighter it will take less energy to accelerate… well not necessarily if you take a small diameter steel shaft and replace it with a lighter large diameter shaft.
Here is an example
7000 rpm a 3” shaft will have a surface speed of 5498 feet per minute
7000 rpm a 4” shaft will have a surface speed of 7330 feet per minute a 33% higher speed
Using basic physics equations like Ke=1/2mv^2 if they weigh the same and most of the mass is in the tube not the end yokes the 4 inch shaft will take roughly 78% more energy to accelerate to 7000 rpm.
If you do all the math the 4” shaft would have to be about 40% lighter to take the same amount of energy to accelerate as the 3” shaft.
What this exercise shows is that most comparisons are apples to oranges you probably won’t see any gains unless you are replacing your current shaft with something lighter and the same or smaller diameter.
And this is without taking into consideration what’s going on in the rest of the car.
For something as simple as a drive shaft there is no simple answer.
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
Old 11-25-2010, 12:37 PM   #23
Eric Merryfield
Eric Merryfield's Avatar
Liked 503 Times in 131 Posts
Here is an example
Well, I just so happen to have a 4 inch steel in my stocker, which came with an aluminum.....so if I change it out of say a 3.5 aluminum, or even a 3" chromoly I will post the results.
Eric
Eric Merryfield 1883 STK
Old 11-25-2010, 03:27 PM   #24
FED 387
Liked 336 Times in 183 Posts
Mr Edgeworth some???? If a 4 inch diameter mild steel tube weighs about 4 times more than a 4 in diameter aluminum tube wouldn't there be some advantage in not having to accelerate that much mass either in HP required or ET resulting from the reduced weight??? Take for example that a .065 steel tube weighs about 3 pounds per foot vs a similiar sized alum tube weighing about .7 pounds per foot there just has to be something here and not just reduced vehicle weight dont ya think????
I can understand harmonics to an extent and the need for OEM vehicles to meet CAFE mileage requirements so the vehicles weigh less but the OEM guys used Steel Deriveshafts for millions of vehicles over the years and really never had any vibration problems so I cant believe that the OEMs replaced the Dshafts for that reason had more to do I bet with vehicle weight that any thing else.
Perhaps you can mathmatically calculate the difference in performance between the 2 or is it too small to actually make any difference---Forget about cost of a shft it is inconsequential just raw performance numbers if ya can please---Thanx Comp 387
Old 11-25-2010, 03:48 PM   #25
KingReptile
Absolute BS that its not legal in stock with all the changes they allow as stated its safer and easier on rear end
KingReptile is offline   Reply With Quote
Old 11-25-2010, 06:37 PM   #26
Bill Edgeworth
To answer your question yes. What you describe would be more of an apples to apples comparison. Same size shafts, same final surface speed half the weight half the energy required to accelerate to speed.
Old 11-25-2010, 07:43 PM   #27
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Originally Posted by Chad Rhodes View Post
harmonic vibration
yep, that's what they tell me,too.mostly OD trans' have that problem for some reason.
Old 11-25-2010, 10:20 PM   #28
Jeff Lee
Jeff Lee's Avatar
I had a buddy with a Cummings diesel Ram truck that had a serious vibration problem. Many trips to the dealer and it was a serious problem when towing his race car. The factory finally put a carbon fiber drive shaft in it and curred the problem. I'm sure there is a TSM on it and it can be applied to any mopar car in Stock.
Jeff Lee 7494 D/S '70 AMX
Old 11-26-2010, 12:25 AM   #29
John Brown
John Brown's Avatar
Liked 13 Times in 3 Posts
The real reason that you would what to use a lighter driveshaft is the critical speed for the length of the shaft. Mild steel is good to a certain length where critical speed makes it impractical or dangerous to use in a racing application. Some racers complain about unbalanced slicks when it really is a driveshaft that has exceeded critical speed and has started to whip and bend while going down the track.
My son (a driveshaft engineer for one of the big three) has always told me that you need the lightest, shortest (hard to do), largest diameter driveshaft made from the stiffest material when building a shaft for racing. When you do all these things you raise the critical speed which will add to reliability and increase performance (if you were exceeding critical speed in the first place).
Stockers that have aluminum shafts already can be improved with larger diameter MMC material which again raises critical speed. Stockers with steel shafts can use larger diameter alloy shaft material.
Super Stockers should always adhere to what was stated in paragraph two.
Note: If you want a larger tube make sure that it fits in the tunnel and driveshaft loops before having it made.
If you want more information go here http://www.markwilliams.com/driveshafttech.aspx .
I am by no means an expert on the subject but I can sure talk to one any time when there is a question.
John Brown 3451 SS
John Brown is offline   Reply With Quote
Old 11-26-2010, 10:19 AM   #30
Tom keedle
Tom keedle's Avatar
i wonder if amc can be included in that
