Old 12-09-2010, 06:16 PM   #1
Ron Middleton
Liked 12 Times in 4 Posts
Default ET Difference with 2.75 low gear
My current '80 Camaro stocker has TH350 with stock low gear and I have a TH350 with 2.75 low gear. 350/190/287 combination in J/SA at 3760 lbs. What could I expect in 60 ft. and ET's with this change?
Anybody out there test the difference on first gear change only? Thanks in advance for help.
#4892 J/SA. We are what we repeatedly do. Excellence then, is not an act, but a habit.”
- Aristotle
Ron Middleton is offline   Reply With Quote
Old 12-09-2010, 07:07 PM   #2
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Default Re: ET Difference with 2.75 low gear
I went from the stock 2.52 low to the 2.75 on my low comp. bb stocker, gained .04 on the 60' about the same in the 1/4.also lost 200 rpm flash on the converter with the low gear. Your car has a sm. blk. and is 130 lbs. heavier so you might gain a bit more. gsa612
Old 12-09-2010, 07:25 PM   #3
GTX JOHN
Our gutless small blocks pick up .05 to .07 with straight cut 2.75 in 60 over stock 2.45. The heavy 318 cars towards the high side and 340/360 toward the lower side. For our mopars about a $1,500. part.
Old 12-09-2010, 09:53 PM   #4
Tom Turner
I got a solid tenth in my 305/q-jet Camaro and .08 in the injected car (90 350 TPI) but (as GSA612 said), the converter becomes an issue. I wish I had the Racepak in the Camaros (too cheap) cuz I think we left a lot on the table back when we were running those cars and I could be more informative. When we put the Racepak in the 96 Corvette, I learned more in 1/2 of 1 season than I thought I knew in all the years before. TT
Tom Turner is offline   Reply With Quote
Old 12-10-2010, 09:42 AM   #5
Tom Meyer
Liked 354 Times in 120 Posts
I have yet to change to a three speed from a glide in my 283 ss car just how much et change could one gain from that change? Also with todays AHFS I not sure now I want to spend the cash just to get HP on my combo. Thanks Tom
Tom Meyer 5240 SS Stock ???
Old 12-10-2010, 10:41 PM   #6
Jeff Goss
Jeff Goss's Avatar
Thumbs up Re: ET Difference with 2.75 low gear
Great question! I would like to know this also. I am no threat to bomb the index, but might like to get my big ol' Wagon moving a little quicker.
Jeff Goss is offline   Reply With Quote
Old 12-11-2010, 01:06 AM   #7
Tim Ellis
Liked 7 Times in 6 Posts
Question Re: ET Difference with 2.75 low gear
How about your reaction times, did they get quicker with the low gear set, seeings how you 60 footed better?
Tim Ellis is offline   Reply With Quote
Old 12-11-2010, 10:31 AM   #8
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
i went from a turbo 400 2:48 first gear to a 904 2:74 and the 60' picked .010 consistantly ,i was hoping to get more out of the 60' the car weighs in heavy ,but you have to be on top of the 1-2 shift it come's up quick ,, i have a 2:45 for the 904 that i might try to see if it changes much gmonde
Old 12-11-2010, 11:12 AM   #9
George Mirza
Ron,
From what I've seen is the car will pick up in 60' but it may struggle after the 2-3 shift. Overall it should pick you up some.
Garret,
Did you pick up .100 or just .010 with the gear change? How much did you see overall going to the 904?
George
George Mirza is offline   Reply With Quote
Old 12-11-2010, 11:56 AM   #10
gmonde
gmonde's Avatar
george :just .010 not anything big but its consistant,,over all the the trans swap was a huge gain a solid 2 tenth gain and 2 mph, the trans is trans i put together with a few aluminun pieces ,,also it was 45 pounds lighter than the th400 gmonde
