Liked 409 Times in 113 Posts
Was looking through the classification guide the other night and came upon the Ford Maverick 302 - 2V combo circa 1972. HP factor appears very soft @ 143 and fit in Q or R. I only know of 1 car running anything similar to this. Why ? Can this combo be competitive or are there problems with this set-up. Just curious. Seems like a low -buck way to class race.
Joe Huestis 9724 L/SA |
1982 Mustang has the bigger carb and an aluminum intake. I may be selling a carb and intake for this combo.
Larry, I can't believe they lumped the 157hp 302 (1982) in with the others. Big cam, 1.23 Motorcraft 2 BBL, aluminum manifold, only drawback is the small port heads. NHRA doesn't have a SBF expert do they? Were I not on a fixed income, I'd try it in Q/Stock and push for an auto for Q/SA. Should run .600 under with an Pep Boy's short block!
Happy Holidays, Fred Holdorf |
Fred the heads should be ok for the carb. There is one of these in Division 3. Check autoimagery for Mike Keener (not the checkmate guy).
There is a racer in Washington, Div6, who is very sucessful with that Maverick 2V combo. His name will come to me. Maybe last name Seaburg??
Liked 223 Times in 73 Posts
Yes Brian Seaburg and Jason Biscane run this combo. The carb is the hold back with this combo. Brian has been at the bottom of the sheets this year but goes rounds. Jason had trouble at Seattle.
#7 | |
It's 162 hp across the board now . Still too high...
Liked 7 Times in 5 Posts
Mark,
The rating was 165 and it being lowered to 162 on January 1st. I have been thinking about a 75 Comet 4 door which falls into T/SA now with the reduced rating. I believe that this rating needs to be about 150 hp. Roland |
Liked 7,781 Times in 1,743 Posts
Nothing wrong with this combo, it's just not a "killer".
Mark, you're just too picky. (save the lecture)
#10 | |
Nah, it's just a geographically challenged combination! Factored tracks, or those right on the edge, 2 bbls, ugghhh :-(
