Liked 9 Times in 2 Posts
The gauge cluster for my Race Pak fits perfectly into the heater vent hole in the center of the dash. Is it against the rules for me to remove it and fill it with the gauge cluster? If it is, could I contend that the car is heater delete and I should be able to remove it?
Thank you, Larry |
#2 | |
Chad Rhodes 2113 I/SA |
Liked 55 Times in 14 Posts
Liked 275 Times in 76 Posts
Place the racepak display in front of the gauge cluster that is original.
Sean
#5 | |
See Stock / Electrical / Instruments.
Jeff Lee 7494 D/S '70 AMX |
Yep, I had to put the AC/Heater controls back in my dash for SS. Guys with the Firebirds do put gauges in their AC vents. I'm probably the only one not to. I see cars with the Racepack dash on the collumn in front of the factory cluster, don't think you can pull the cluster.
Ed Wright 4156 SS/JA |
I am retianing my factory cluster. It is a lot more difficult to put the race pak in front of the stock cluster than in front of the heater register. Also I have been told (not from NHRA) that I could remove the heater controls because the car is a heater delete from the "factory". Maybe I should call NHRA tech for clarification?
Thanks, Larry |
If a car is indeed a factory "heater delete" car, then why does it have any heater controls in it?
Not what I was told.
