#51 |
2004 GTO just picked up from JRC last month. Original plan was stock, most likely super stock now in GT/HA, and some NMCA heads up stuff.
#52 |
Nice should be a ton of fun
#53 | |
Liked 502 Times in 130 Posts
....the new stocker is jealous.... the dakota got a bit more magnum motor..... the lil red wants that magnum.... the other challenger got the left over 727 and will run Super Street.... Eric
Eric Merryfield 1883 STK |
#54 |
Liked 12 Times in 5 Posts
Older technology 4 link fiberglass spring suspension in this 65 Belvedere 1. Picked up
most of the major parts for a hemi today. But it will be a while. SS/DA car with a 4 barrel race hemi. |
#55 |
Liked 44 Times in 13 Posts
Looks like we will be out testing in late January so will post ours here also...
Mack Reeves 2377 STOCK & SUPER STOCK |
#56 |
Liked 241 Times in 100 Posts
GTX John,
Here are 2 pictutres from 84. Who did you buy it from ? |
#57 | |
Liked 2,753 Times in 974 Posts
Wade,
When can we expect to see the Vette and what Super Stock class will it run? Quote:
#58 |
Liked 69 Times in 9 Posts
#59 |
I am putting this '77 Olds Starfire GT together for stock. Right now the drive train is out and the interior is completely stripped, only the steering column/wheel is left. Next up is subframe connectors and some floor repair. Paint / body work will be next winter. Hoping to have it running this year for some check out passes. Looking at V/SA to get my feet wet with a Buick 231 V-6 for power.
Rick |
#60 |
Liked 18 Times in 8 Posts
Frank, I'm right in the thick of the "Best Engineered" portion of this build. The stuff where folks go how did you do that? or Why did you do that? or what does that do? LOL Actually, I'm repairing all the little stress cracks that seem to be unending. But it's on the rotissorie, so now is the time to do it and do it right. Once I get paint on it and back on the frame, I think it will move along swiftly. The tough stuff has been long done, and I can see the light at the end of the tunnel. Hopefully it will be done early enough to get some real good seat time this fall. I'm just hard headed and must do all of the build myself.....design, engineering, fabrication, body, paint, plumbing, wiring, etc etc. That's just how I believe hot rods should be done. Anyway, I believe it fits in "L" naturally, but who cares....as long as there are no DPs and CJs untill the eliminator.
Wade Mahaffey |
