Liked 205 Times in 93 Posts
so are they legal for SS now? i can get a 4" bore unit reasonably priced and would like some "classracer" opinions on going in that direction please...
Liked 9 Times in 3 Posts
there's a list on the nhra website. i believe the only choice is the dart little m sportsman block.
Mark Markow 171 ss/tb |
is there any advantages/disadvantages in using a dart over a bowtie block? i want too spend my once in a lifetime/hard earned cash investment properly. thankyou...
Banned
Liked 22 Times in 22 Posts
I don't know about u guys, but I have yet to see a junk bowtie block, over priced,maybe? Junk, I think not.
don,t have one |
#6 | |
Liked 362 Times in 105 Posts
Been there done that... and it was not even close on a choice. Dart is much superior in almost every way. When I bought mine the GM block was actually higher in price by just a little, but price was not the deciding factor for me at the time. My 2 Cents |
Liked 1,929 Times in 434 Posts
Unless they've changed, Dart was using the same foundry and the same material as GM. GM has gone to a very high quality CNC process. They (BowTie blocks) were never junk, but Dart surpassed them in quality at least for a while.
Make sure you compare apples to apples when you compare blocks, don't compare the cheapest two bolt main cast cap BowTie block to a Dart Little M, that's not a reasonable comparison. At one time, GM had a few BowTie blocks that were specifically intended to be cheap and small upgrades from production blocks. They were really meant to pass tech as a factory block in low budget classes so that racers who had to run a GM block could have an alternative to used up worn out salvage yard rejects. They were not meant to be a real "aftermarket" block for high end racing.
Alan Roehrich 212A G/S |
Liked 166 Times in 54 Posts
what block is legal for the SS SBF?
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
According to the list, there are none. The only accepted Ford aftermarket blocks on the list (page 89-90) are for the FE.
#10 | |
