I know this has been on here before, but I can't find it.
Couldn't find it in their catalog, so I called AFCO. They have a low friction, but not an extended length stud ball joint for a '67-'69 Camaro. Who does? Part #? Thanks,
Bobby & Norene Zlatkin L/SA |
Liked 333 Times in 180 Posts
afco 20034-1 & 20038-1 upper and lowers
Are you sure FED387? AFCO lists #20034-1 as a screw-in ball joint for a Ford Pinto.
Liked 16 Times in 11 Posts
Sent Link, in PM
Bob Pagano A/SA |
Last time I talked to Afco they only had them for the G-Body's. Howe has them for everything you can think of. But everybody tells me if you use the Howe ball joints, your car will turn left at the end of the track.
Alan Warman STK 4107 |
Liked 9 Times in 3 Posts
qa1 makes them . heres the link http://qa1.thomasnet.com/viewitems/b...001448|3001453
Mark Markow 171 ss/tb Last edited by Mark Markow; 01-18-2011 at 10:27 PM. Reason: added link |
Liked 60 Times in 12 Posts
LMAO @ Alan !!!!
2894 STK |
Liked 759 Times in 379 Posts
Coleman Racing Products has what you are looking for...
http://www.colemanracing.com/Ball-Jo...ize-P4401.aspx |
I believe you will be much happier with the quality of their products www.howeracing .com The studs come in 5 lengths and rebuidable. Use locktite on set screws assemble with oil.
