I have always been amazed at the amount of horsepower Stock Eliminator racers have been able to extract from their cars. I would think that the engines must be extremely efficient, squeezing the last bit of hp from every drop of fuel.
My question is, what do you guys do to the engines to make them run so strong on seemingly mundane parts? I realize some basics like fully balanced rotating assembly and cc' ing the heads would help, but what else? I'd like to apply some of the things to my street engine when I rebuild it. Thanks, Dan |
#2 | |
Banned
Liked 235 Times in 110 Posts
#3 | |
Liked 132 Times in 30 Posts
I was talking to another racer yesterday about the very same subject. Too many racers looking to go fast fail to look at the most basic areas. I'm sure there will be others that chime in on this subject and should offer some interesting answers.
Gary Smith "another broke racer spectating" |
Liked 3,222 Times in 980 Posts
X-TECH MAN is right on, for the street it's hard to beat stroker motors that remain pump gas friendly. Correct clearances, file your ring end gaps, etc. are essential and let a good shop bore/hone your block. Also, given the tighter convertors (you do NOT want a "stocker" convertor on the street any more than you want 5:13's) cam selection is absolutely critical. Don't catalog shop, talk to one of the reputable cam makers and tailor the cam to your combo. Finally, get all the weight out of your car that's practical, it pays dividends in every area of car performance.
P.S. Crate motors are a pretty good deal but again selection is key and cubic inches rule. If you decide to go crate motor then start a new thread soliciting feedback, there is a wealth of knowledge on this forum. Also helpful to indicate your current car/motor. Every make has it's own following.
#5 | |
Liked 1,890 Times in 423 Posts
What few people understand is that most Stock Eliminator cars are not fast just because of the engine. It's the entire car, and all the tuning and work that goes with it. The engine is important, don't get me wrong.
Most people can't take around 600HP in a 3300# car and run 9.90 with it in good air.
Alan Roehrich 212A G/S |
Thanks so much for the responses! I feel I understand the class a little better now, much more going on behind the scenes than I realized. There is definately a lot more to it than a common weekend bracket car.
Some of the things that I'm planning for my motor are; 1.) balance the rotating assembly 2.) cc the heads 3.) port the heads, working to improve flow and velocity instead of just hogging out the ports. 4.) keeping the stock size valves or maybe a slight increase, again for velocity. 5.) 3 angle valve job 6.) match port everything 7.) keeping the stock carb (maybe??? don't know yet) 8.) headers, small tube 9.) stock compression Just trying to make it the most efficient, make decent power without killing gas mileage. What do you think? Am I on the right track? Missing anything obvious? A few questions, though. Does an increase in overlap work the same as higher lift on the cam. If it does, I guess you guys are limited on your lift, so you acomplish the same thing with overlap. Am I kind of right or COMPLETELY wrong? Also, does an increase benefit torque or top end? Again, thanks for everybodys patience with a new guy. Dan |
Liked 10,836 Times in 2,252 Posts
Dan you can do all of your list and pick up power, remember hard smart work is what it takes. OR.....................
You can do what Mr. Bill did and get Shelby to change all the spec. 20 years later. Most S/SS racers work very hard to use the power they make to turn the wheels. |
Dan,
Stock cams not only have a lot more duration and overlap than you'd want, but also a lot more aggressive lobe profile than you'd want in a street flat tappet cam. Attention to detail is what makes Stock engines run. Honestly, using a set of aftermarket heads with modern ports and combustion chambers will get you years ahead of what we're working with to make these older heaps go fast. The same thing with pistons, more efficient dish/dome profiles, better skirts, and better ring packages will be a lot cheaper and work better than what we run. What you need to take away from the typical Stock program is the attention to detail and the blueprinting that allows us to make the most of the limited stuff we have. The use of torque plates, the perfect hone finish, the blueprinted locations of the deck, the main bearing bores, the lifter bores, the cylinder bores, and the exacting tolerances and clearances.
Liked 13 Times in 7 Posts
Good answer, Alan
Richard Grant 4988 STK |
