Old 02-03-2011, 10:01 AM   #11
Kegracing
Default Re: Help cutting Moroso trick springs please
Thanks Clark. Your car looks very nice.
Sounds like about 3/4 is the starting point.
Ken
Kegracing is offline   Reply With Quote
Old 02-03-2011, 02:18 PM   #12
cad
cad's Avatar
Liked 93 Times in 52 Posts
Thanks Ken.
One suggestion, if possible, contact any local shops that manufacture springs and see if they will professionally compress and band the springs.
Even with 3/4 coil cut, it took the compressor, and 2 large pry bars to get them into position.
http://www.thomasnet.com/northern-te...7570604-1.html
Clark
Old 02-03-2011, 02:48 PM   #13
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
That K-D J hook tool allows you to compress any coil spring enough to install it with ease. You can compress one straight or stagger the hooks and arc the spring a little just like they sit in many cars.
I installed many springs and did it with NO spring compressor a lot. At one time back in the early 70's.......lots of guys jacked their cars up higher for the street as it was the "cool thing to do" . I used to have to resort to all kinds of tricks to get them in......I would have a car on a center post lift and put a jack stand under the opposite rear corner from the front where I was trying to get a stiffer than stock spring in......Car would be nose down on that front trying to get enough weight on there and me struggling with a tire bar to get the nut on the upper ball joint.......Never had one I didn't get in there but it was no picnic.....The j-hook tool was a big improvement. I still have it in my toolbox...
Rich Biebel
S/C 1479
Stock 147R
