Old 03-18-2011, 06:11 PM   #1
doglover44
doglover44's Avatar
Liked 493 Times in 231 Posts
Default Stock/Super Stock Difference
Whats the diffrence between Stock and Super Stock ? What makes Super Stock well Super ?
Jake Biermann
Old 03-18-2011, 06:54 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Stock/Super Stock Difference
Got a rulebook, or been to a race to look around?
Ed Wright 4156 SS/JA
Old 03-18-2011, 07:05 PM   #3
Jim Cassels
9000 rpm vs 6800 rpm plus some other incidental stuff.
Jim Cassels is offline   Reply With Quote
Old 03-18-2011, 07:09 PM   #4
cicero819
cicero819's Avatar
Liked 69 Times in 30 Posts
Difference between Stock and Super Stock is basically allowing a little more freedom in modifying your vehicle between both categories. Super Stock will allow you to have a more intense building of your motor such as aftermarket aluminum rod, different crankshaft, more compression that the original motor came with, better intake but must retain the original carb. You're allowed to have a better rear suspension(4 link is the norm with shortening of the rear end and the use of wheel tubs to allow for bigger and wider tires) all these modification aren't allowed in stock eliminator. Stock most appear to be stock and are allowed only certain modifications such as blueprinting of the engine and transmission, rear end must stay within the factory specs. I hope this helps. Both are great categories to watch and race in, most of the racer are great bunch of guys who will have no problem sharing more information than I can. Enjoy. CR
Old 03-18-2011, 07:21 PM   #5
Stocker 2
Originally Posted by cicero819 View Post
Super Stock will allow you to have a more intense building of your motor such as aftermarket aluminum rod, different crankshaft, more compression that the original motor came with...
What rulebook did you get that out of? Those are okay in the modified S/S classes but definitely NOT in regular S/S or SS/GT.
Stocker 2 is offline   Reply With Quote
Old 03-18-2011, 07:37 PM   #6
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Talking Re: Stock/Super Stock Difference
More $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ !
Old 03-18-2011, 07:41 PM   #7
cicero819
cicero819's Avatar
Stocker2 I was just trying to explain the difference in a simple easy to understand way. Look ,what do you expect from someone who throws grenade for a living. my motto "as long as it's close".CR
Old 03-18-2011, 08:04 PM   #8
Stocker 2
And I was just trying to make sure the correct information was given as an answer because "as long as it's close" does not work in the teardown barn.
X-Tech Man best summed it up. More $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Old 03-19-2011, 08:19 AM   #9
Greg Hill
Liked 279 Times in 68 Posts
About $20k difference in motors.
Greg Hill 4171 STK
Old 03-19-2011, 10:18 AM   #10
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
The short version is that a Stocker is limited by 9" wide slicks, un-modified body including wheel tubs, no trans brakes.
As for the engine difference, a Stocker is limited to stock lift cam with stock type lifter for that engine and stock rockers too, where as a Super Stocker has use of any valve train, generally radical roller cams with billet rocker systems. The Stocker is supposed to use factory "un-ported" heads and intake manifold where the SS get highly massaged heads and any intake, but they both have to use the factory carb for that combination.
It's complicated beyond this, but I hope this helps a little. TP
Pedigo Perf is offline   Reply With Quote
