Liked 129 Times in 59 Posts
Has anyone had any bad experiences with solid motor mounts? I had heard that they could deform the cylinder block. Would the poly mounts with a torque brace be more efficient? Should a solid tranny mount be used with the solid side mounts?
![]() Thanks! Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
Liked 93 Times in 52 Posts
A couple folks that I know personally have cracked their automatic transmission housings using a solid transmission mount.
Most use solid engine/frame mounts that I know of. Clark |
Ran them on my wagon Lew and never had a problem....
Danny Waters, Sr / 73 Duster "340" |
Liked 20 Times in 15 Posts
Solid fronts mounts
Solid mid mounts Stock transmission mount on fabbed cross-member |
Liked 1,883 Times in 423 Posts
Solid motor mounts, a torque restraint, and a polyurethane transmission mount, is the ideal setup, if you're not allowed motorplates. And even with motor plates, front and mid, I use a polyurethane transmission mount, never a solid.
Alan Roehrich 212A G/S |
Liked 759 Times in 379 Posts
Used solid mounts and a rubber trans mount for the better part of the 17 years and over 4000 passes I made with this nearly 2 ton ride, without issue. I would never used a solid trans mount.
Thanks, everyone!
I'll pick up the mounts this week. Lew
Just wondering, why do they even make a solid tranny mount? I don't know anyone the uses one and everyone will tell you to never use one unless you enjoy broken cases.
Circle track guys use them. And people you can't tell anything will try them, then wonder why they're having problems.
Liked 13 Times in 7 Posts
Full Chassis cars with 2x3 frames rails. Both of our cars had solid trans mounts and never busted or cracked anything.
N/A |
