Old 03-25-2011, 02:47 PM   #11
danny waters sr
danny waters sr's Avatar
Thumbs up Re: Solid Motor Mounts - Good or Bad?
Originally Posted by mannymen View Post
Full Chassis cars with 2x3 frames rails. Both of our cars had solid trans mounts and never busted or cracked anything.
I think Lew is building a stocker , there would be a diff.
Old 03-25-2011, 03:23 PM   #12
Default Re: Solid Motor Mounts - Good or Bad?
Originally Posted by Lew Silverman View Post
Thanks, everyone!
I'll pick up the mounts this week.
Lew
Lew, pick up one of those red poly "Energy Suspension"? trans mounts from Jeg's or Summit. Nice piece, and well worth the difference over the $10 Chinese crap.
Old 03-25-2011, 06:39 PM   #13
Todd Boyer
Liked 6 Times in 5 Posts
I've even heard that using a poly trans mount can cause broken extension housings. Was advised to use a stock rubber mount. This was in a small block Mopar A-Body.
Old 03-26-2011, 02:23 AM   #14
Jeff Lee
Jeff Lee's Avatar
Anybody try a front and mid-plate and no tranny mount?
Jeff Lee 7494 D/S '70 AMX
Old 03-26-2011, 02:30 AM   #15
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Red face Re: Solid Motor Mounts - Good or Bad?
I hate to blow everyone out of the water but dad's Camaro has solid engine & trans mounts & I bet it has made more passes then anybody's on this forum in the last 20 years with no trouble! (it is just a "bracket" car though, high 12's)
Old 03-26-2011, 08:03 AM   #16
Signman
Liked 269 Times in 99 Posts
To over simplify it: Chassis Flex.
When the engine puts applies torque to the chassis it rotates it. The twist is what makes the left front wheel lift more than the other. Solid mounts make the engine & trans. part of the structure of the chassis. If there is flex in that area the weak point is generally the trans. case.
My 2 cars have solid engine mounts and stock rubber trans. mounts.
Poly mount will be more stiff than rubber so if you have little flex your good.
All solid mounts would guess there is not much flex in that area.
Have seen cars with front and mid engine plates both with and without trans. mounts.
It's about engine torque, chassis stiffness and the resulting flex when torque is applied.
My .02
Old 03-27-2011, 09:23 PM   #17
et7333
et7333's Avatar
I've used solid motor and trans mounts for over 25 yrs in both my 64 nova bracket car,put over 6000 passes on this car before I sold with solid mounts.My current Camaro has solids mounts and I've put about five thousands passes on this car with no issues using solid mount for trans and engine.
http://stevecoxracing.com
et7333 is offline   Reply With Quote
Old 03-27-2011, 09:59 PM   #18
Todd
Todd's Avatar
We have used solid mounts in our bracket car and our stocker, both engine and trans for years without problem. Good luck with your build.
Todd Melville
Melville Racing
1577 T/STK
Todd is offline   Reply With Quote
Old 03-29-2011, 11:54 PM   #19
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
Years ago when I ran the three speed I had solid front mounts,solid bellhousing mounts and no transmission mount. Never had any problems but would not do that again.
Since going to the four speed I have added the trans mount.
55 Chevy is offline   Reply With Quote
Old 03-30-2011, 09:18 AM   #20
BadCamaro
off topic, would anyone know the part number for the bbc solid mounts for camaro (68), the moroso's
BadCamaro is offline   Reply With Quote
