Old 03-27-2011, 09:35 PM   #11
Todd Boyer
Liked 6 Times in 5 Posts
Default Re: The "Answer" brake pressure switch
Originally Posted by Lew Silverman View Post
Todd,
It's a Normally/Closed switch - you don't want the pressure switch activating in high gear. The wiring schematic shows it better!
There maybe an adjustment on it, although I haven't found it. I guess it would depend on what pressure you wanted the two-step to kick in.
Lew
So it's a switch that is activated by the shifter as it goes into high gear ?
Old 03-27-2011, 10:08 PM   #12
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Todd,
That's it! It's disabled in high gear.
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 03-27-2011, 10:16 PM   #13
Todd Boyer
OK, Thanks Lew !!!
Old 03-28-2011, 11:12 AM   #14
Robert Simpson
Liked 20 Times in 12 Posts
Question Re: The "Answer" brake pressure switch
Can you explain why it would be plumbed into the rear of the M/C vs the front? I assume it is the pressure of the switch. Does it say what pressure to make the switch activate and how do you know what it is? A gauge?
Thanks
Robert
Robert Simpson is offline   Reply With Quote
Old 03-28-2011, 11:18 AM   #15
art leong
I would use a normally closed switch in the high gear line pressure checking point.
Or I would use a normally open switch in the low gear checking point. On my trans the low gear uses much higher pressure.
Art Leong 2095 SS
Old 03-28-2011, 09:35 PM   #16
Phillip marvetz
Phillip marvetz's Avatar
I have my switch plumbed into the front brakes, I can adjust the pressure it takes to activate it and have a pressure gauge on the dash.
2009 V/SA Record Holder
Old 03-29-2011, 10:23 AM   #17
cecilfrazier
George you have pm
Cecil Frazier 1137 STK
cecilfrazier is offline   Reply With Quote
