Old 03-30-2011, 09:59 AM   #21
mannymen
Liked 13 Times in 7 Posts
Default Re: Solid Motor Mounts - Good or Bad?
I believe I used the 62510s in Chrome when they still had them. Make sure your bases mounts are correct.
N/A
mannymen is offline   Reply With Quote
Old 03-30-2011, 11:03 AM   #22
Jeff Lee
Jeff Lee's Avatar
Originally Posted by 55 Chevy View Post
Years ago when I ran the three speed I had solid front mounts,solid bellhousing mounts and no transmission mount. Never had any problems but would not do that again.
Since going to the four speed I have added the trans mount.
Why not? I'm just looking at one last step in R&R trans.
Jeff Lee 7494 D/S '70 AMX
Old 03-30-2011, 11:09 AM   #23
Jeff Stout
Liked 706 Times in 283 Posts
Solid motor and trans mount.Car was built in 1985 and only suffered 1 broken trans case. No anti roll bar and car does twist. I agree it doesnt sound like it should work but it seems to be fine.
Old 03-30-2011, 02:48 PM   #24
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
In my case I have changed to a Ford Toploader and with the cast iron case it weighs a beastly 110 lbs. Felt it would be too much weight hanging off the back with no support. It may or may not be a problem but did not want to take a chance on breaking an ear off or worse.
Once the Jerico is in next year I might leave the rear mount off as the trans is 40 lbs lighter.
Allan
55 Chevy is offline   Reply With Quote
Old 03-30-2011, 04:49 PM   #25
BadCamaro
wow they had chrome ones? Yea I just picked up the bbc stands brand new at local swapp meet. I have the correct x-member too...the only mounts I see from moroso are in gold..
BadCamaro is offline   Reply With Quote
Old 03-30-2011, 07:05 PM   #26
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Paul Crowe told me story one time about driving a 55-57 chevy, no crossmember.I can't remember which but anyway he crossed finish line heard bang ,evidently lost driveshaft and broke trans threw all on the ground,he said that was weird feeling for shifter to yanked out of your hand and disappear.
Mike Taylor 3601
Old 03-31-2011, 10:35 AM   #27
55 Chevy
55 Chevy's Avatar
Mike Taylor 3601
Yikes! On that note the cross-member stays when the Jerico goes in next year.
Allan
Old 03-31-2011, 10:43 AM   #28
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Mike Taylor 3601
Much as I remember (and it's been a while!), didn't the 55-57 Chevy have the rear mounts on the bell housing? Or was that just on the trucks?
I once had a Top loader in my Nova that bent the factory crossmember before I braced it, a little heavier than a muncie.
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 03-31-2011, 10:47 AM   #29
Robert Simpson
Liked 20 Times in 12 Posts
Talking Re: Solid Motor Mounts - Good or Bad?
[QUOTE=55 Chevy;249686]Yikes! On that note the cross-member stays when the Jerico goes in next year.
You will like the Jerico better..Also my father had a old B/W 3 speed blow most of the case off and the main shaft and the drive shaft stayed together! He did say there were some shifting rods draging the ground because he was holding onto the shifter, so it would not drop onto the track. Ah yes he said the good days of Junior Stock. That was in his 55 wagon I think.
Robert Simpson is offline   Reply With Quote
Old 03-31-2011, 11:47 AM   #30
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Robert -
I had the same experience with my first car - '57 150 Business Coupe 283 2-bbl. After NHRA outlawed the four speed, I tried a three speed. Spent a lot of money on a lot of new parts and modifications on the 3-speed. When I got it together, I threw mufflers on it, drove it around to break it in, then one blast down the highway to try it out. The one blast blew the cluster gear out on to the street on the one two shift.
