#11 |
Art,
To convert the MM feeler gauges to standard just multiply by .03937. 1mm x .03937= .03937 .5mm x .03937= .01968 |
#12 | |
Liked 231 Times in 107 Posts
I'd cut the adjuster boss down to where you can get a wrench on the adjuster in there real easy or if this is a super stock motor I'd weld the adjuster to the rocker and make the pad that the rocker sits on stationary. (as long as there's room for cam/cams |
#13 |
Liked 880 Times in 311 Posts
Art,
What is the actual Rocker Ratio? You know,measured... Measure the lobe lift and then the valve lift @ "0" lash. Then divide the required lash, at the valve tip, by the RR and set at the roller. You do realize with a set up like that you can alter the RR with tip length of the valve. It can also move the cam timing around a little.
Adger Smith (Former SS) Last edited by Adger Smith; 04-09-2011 at 09:42 AM. |
#14 |
Liked 544 Times in 213 Posts
Get a pair(1 Int and 1 ex) set at the valve to whatever lash you want and then see what it is between the cam and the roller. A feeler gauge should work ......Once you know the number that is at the cam/roller with the proper lash at the valve tip..... set them all at the cam/roller contact area. They do make very thin open end wrenches once know as tappet wrenches that might work on the adjusters...
I agree that motorcycle engine mechanics would have tools to do this....My son has been around motorcycles all his life...... I also think Terry's idea of cutting the bosses down is a very good one......Not real hard to do it either.....
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 04-09-2011 at 05:06 PM. |
#15 |
I'm thinking of cutting the bosses down some Fabricating a wrench that I can use on there. Possibly drilling holes for set screws to stop the lifter from turning.
But this will probably be for next season.
Art Leong 2095 SS |
#16 |
Liked 5,138 Times in 1,961 Posts
Never mind . It looks like you don't have any room to close up the adjuster height any.
Yep. Machine the bosses down when you get the head off.
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 04-10-2011 at 04:02 AM. |
#17 |
Liked 20 Times in 12 Posts
Art
Rich is correct about the tappet wrenches, Sears sells them.They are about .250 thick. Rich |
