#41 | |
I've been around NHRA for over 40 years now, and I just have an idea how they think most of the time. I do think that they put some of the vague, ambiguous language in there just to give themselves wiggle room . As to your question, the aftermarket steel case is close enough to OEM in weight and density, that it's considered a replacement part, similar to a Moser 12 bolt (Technically not OEM either). I got busted at Gainesville years ago, for having a Moroso aluminum water pump on a 283 Stocker . I painted it black and all, same as the engine. I knew it wouldn't fly if it was ever spotted. I happened to have a cast iron spare in the truck, ready to go on . LOL
#42 |
Liked 17,559 Times in 1,598 Posts
I think your forgetting the golden rule, if it does not say you can, it means you can't.
Mark, lets just say I don't agree with any of your interpretations of the rules that I mentioned, especial the one that effected me. Oh yes, that's exactly what I thought you would say, I just wanted to see you type it. Jeff, one more time, NHRA told me it is not a performance advantage, that argument is over. |
#43 |
Liked 11,010 Times in 2,263 Posts
Bill dont forget drive by wire!
I'm going to get one of the new 8 4/4 so i can get better gear selection and rear suport on the pinion... |
#44 |
Liked 294 Times in 93 Posts
Larry does a Mopar 8 4/4=a 9" Ford??
RJ |
#45 |
You have mentioned that you want a clarification of the rule. Who would you like to hear this from? Does NHRA employ someone who has the authority to "clarify" something in the rule book?
#46 |
2009 V/SA Record Holder |
#47 | |
Really? Then why is the aluminum center section not allowed at present? Apparently somebody disagrees. Must be the "other guy" at NHRA.
Jeff Lee 7494 D/S '70 AMX |
#48 |
RJ they do look the same and all the parts interchange.
#49 |
Larry
Thanks I believe that I'll try one of those Mopar Aluminum units in my car. They still pay don't they?? RJ |
#50 |
Liked 279 Times in 68 Posts
This is just another time when they don't follow their own rule book.
Greg Hill 4171 STK |
